Ok I have a real noobish question, my apologies.
I have an old Denon AVR-3300 Receiver (I know I should upgrade
), I just picked up an SVS SB12-plus subwoofer. After looking at the inputs of the SB12-plus and the outputs of my Denon AVR-3300 it looks like I want to use an RCA cable to go from the Denon to the SVS, correct? Do I want to use TWO RCA cables? What is confusing is when I look at the back of the Denon it shows this for Preamp Outs (periods added for spacing):
...........................CENTER..........
L......O..........O..........O.........O...
R......O..........O..........O.........O...
..MULTI/...................SUB............
..EFFECT.SURROUND.WOOFER.FRONT.
So obviously the "R" SUB WOOFER out looks like what I should use, should I also use the above "L" output even though it is labeled CENTER or will this have the wrong signal attached to it (after surround sound processing takes place)?
I want to order my cable(s) from monoprice before my subwoofer arrives and I just want to make sure I pickup the right cables. Also if I only use the "R" SUB WOOFER output is it recommended that I split this into 2 RCA cables and input them both into the SB12-Plus (I would think by 5.1 the .1 is subwoofer and 1 cable should suffice, but my subwoofer has L & R inputs)? I am sure this is a real stupid question, and my apologies for asking, but this is my 1st sub.
This cable should be fine right?
