Status
Not open for further replies.
1 - 6 of 6 Posts
I'm on the north side of Chicago (4500n). I'm guessing maybe 6 miles or so from where just about everything is being transmitted. I figured being so close I could probably get an indoor antenna to work but so far haven't had much luck. I'm using one of those MegaWave antennas right now and have a lot of dropouts. WGN I can't ever seem to get a signal. So I figured I might just bite the bullet and try to get an antenna on the roof. Any recommendations on what I would use being this close? The other posts I've seen were mainly concerning locations farther out. I'm in a 3 story building. There's nothing really taller than that close by. I figure I need a VHF/UHF for when CBS eventually starts broadcasting on channel 3.
Also I was planning on using a diplexer because I'm not allowed to run any more wires to the roof. Are there any problems with using those that I should be aware of? Any help would be appreciated.
-Andy
Banned
Before you make any major purchases you should at least give the Radio Shack Double Bowtie a try. I don't remember the cat no. right now but if you can't find it let me know and I will hunt it down for you. (you can also search the HW forum. This antenna has been covered quite a bit here).
Trust me, from 6 miles there is no reason why the RS double bowtie shouldn't work for you. I have successfully used this antenna from over 25 miles away!
Frankly, I'm suspicous why a simple UHF loop doesn't work at that distance so consider it might be the way you are hooking up your antenna.
Anyway, good luck.
Rick
The RS part number is 15-623.
Good luck.
Casey
I'm at the same distance (Lawrence and Kedzie) and a rabbit ears and bow tie did not work with my first generation reciever, a Unity Motion HDR-1000. This may sound insane, but I bought Radio Shack's cheapest outdoor VHF/UHF antenna and set it up indoor. I have it in the space behind my front projection screen. Works great!
The Radio Shack double bowtie antenna is a good idea to try. You should keep in mind, though, that WBBM-DT (once it's actually broadcasting) will be on VHF channel 3, and the bowtie is UHF only.
1 - 6 of 6 Posts
Status
