Looks good Hip Hop. I did see your post in the forum previously, where you thought you copped a bit of heat for your comments. Not sure why you are upset but there you go.
Your set up does look nice and I am sure that it is great for you. Ultimately, it is irrelevant what others think of your set-up...as long as you are happy with it that's the only important factor. However, as you say, it is not a home theatre set up and is probably better listed in the home theatre / media room section. In any case, the majority of banter in this forum results from the actual construction process. It is an invaluable resource for tips, advice and assistance. If you feel that you would like to show off your components, I am sure you will find more feedback in 'show me your completed theatre' forums, find a thread relevant to the components that you have chosen and the like. I would urge you to spend lots and lots and lots of hours reading through the threads here and you will find that in the great majority of builds, the room is the dominant part of the theatre.... otherwise it's just, as you say, a TV and speakers.
