1 - 7 of 7 Posts
first off new here.well been searching all night and still cant find an answer.the problem i am having is that i bought th tv from a cousin of mine and he didnt have the remote for it,therefore i went and bought a universal remote the GE 24944 to be exact(cheap and convenient so i thought).well now i can get the remote to connect to tv but the problem i'm having is i'm only receiving 13 channels and the rest keep showing with no signal.i've tried coding the cbl/sat button to no avail.i can press the menu and it'll pull up the menu bar but won't let me do anything as far a settings.so what could be my problem ? also i'm using cox cable with no digi box but i dnt see how that would be a problem when i can hook cord to previous tv and channels will show fine.do i need to do a firmware update,if so how ? thanks for any help in advance
LG 55" C9 OLED, Yamaha RX-A660, Monoprice 5.1.2 Speakers, WMC HTPC, TiVo Bolt, X1
When was the last time you used a TV to tune channels from Cox?
They may have changed their systems, like many cablecos, so that most channels are encrypted and not available unless you use a cable box or a device with a CableCARD tuner.
The only channels you'll probably get are local channels, gov/edu/public service, and shopping.
Check the HDTV Locals forum for your area and see if others can add more info.
Thread Ender
It sounds to me like his "new" TV is set to tune OTA analog channels, and he is getting analog channels 2 thru 13 over the cable line . . .
He needs to find a way to set the TV to receive cable channels. Maybe he's got the cable line connected to the antenna coax input (if there are two seperate inputs). Unusual not to have the proper remote.. unless the TV came from Midnite Audio/Video Supply . . .
As far as I know, Cox has encrypted its basic analog tiers in few if any markets. I suggest the OP read the manual if he has one. If not, he should download one from http://shop.panasonic.com/shop/model/TC-P42X1
Additionally, I suggest he get an equivalent remote at somewhere like http://remotes.com/store/panasonic/tcp42x1.html
Discussion Starter · #5 ·
exactly what i'm getting.and its connected right. no midnite a/v supply here lol.he upgraded to a led tv so didnt too much care for this one.guess i'll try to find a way to get it to receive the cable channels or just purchase the original remote online
Thread Ender
If you have the manual (or look at the one online that domino linked to) maybe you can find how to enable a scan for cable channels on the antenna input. Did your cuz use it OTA only?
mysta405:
Welcome to the forum.
Did you look at the manual as domino92024 suggested? Manual here:
service.us.panasonic.com/OPERMANPDF/TCP42X1.PDF
...i'm only receiving 13 channels and the rest keep showing with no signal.i've tried coding the cbl/sat button to no avail.i can press the menu and it'll pull up the menu bar but won't let me do anything as far a settings...
I agree; you need to get into the menu to change the set from antenna to cable.
Until you get an original Panasonic N2QAYB000321 remote, you can use the buttons on the back of the set to get into the setup part of the menu....see the attachments.
Please let us know how it works out.
1 - 7 of 7 Posts
