1 - 20 of 103 Posts
I am getting ready to purchase some Yamaha NS-777 floor speakers for a home theater set up. I will be purchasing the rest of the speakers in that same class for a 5.1 surround sound soon. Right now I am concentrating on the floor speakers and a nice Amp for them. They are 6ohm speakers and I will most likely B-Amp them. What would work best for a receiver? Maybe separates? I'm not sure as this is my first home theater set up other than HTIB.
I would suggest mating Yamaha speakers to a Yamaha amp/receiver. I'm sure they were made to work well together.
Much like JBL speakers with H/K amps/receivers (same company).
But don't bother bi-amping, complete waste of time, unless you are going to active bi-amp. And that is a whole different thing.
Originally Posted by 4DHD  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22983409
My experience is that companies that make receivers, other than Harmon, don't make good speakers. There is no "magic" matching of speakers with receivers/amplifiers.
+1. The best plan is to select the best components from the manufacturers who excel in each particular field. It is extremely unlikely that Yamaha will be able to compete with well-respected specialist speaker manufacturers. Similarly, whatever speakers one has, one needs to choose the most appropriate AVR for one's needs. For example, if electronic room correction is important to you, then Denon or Onkyo (which incorporate Audyssey) would generally be considered a better choice than Yamaha.
Originally Posted by SonomaComa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22983328
I would consider Denon or Onkyo AVRs. 'Passive' Biamping is a waste of time and wire see here for info:
Passive Biamping - AKA 'Fool's Biamping '
What is it about the Yamaha speakers that attracts you to them, over, say, any of the numerous well-respected brands?  Also, will you be using a subwoofer?
Originally Posted by Theresa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates/0_50#post_22983415
The op is not asking about speakers. As such I don't care what brand he might buy. If he wants Yamaha speakers, its his choice.
There is "no magic matching?"...there certainly is synergy that can come into play. Through experience, I'll match JBL speakers with HK, Parasound, Marantz before I'd ever use Onkyo, Yamaha, Denon.
Discussion Starter · #7 ·
" I have heard the speakers and for a home theater set up they sound great. With 2-8" woofers, 1-5" mid-range, and a 1" tweeter they have excellent sound especially for dialog. It's nice to hear a speaker that has woofers, mid range, and a tweeter.
http://usa.yamaha.com/products/audio-visual/speaker-systems/home-speaker-systems/ns-777/?mode=model
And since they do make great receivers I figured I would try and keep it all Yamaha, if that's a good idea. I was thinking of bi-amping because they are 6ohm speakers to begin with and they have two 8" woofers that may take away some power from the Mid and tweet. There is a nice picture of them in that link I posted above in case you aren't familiar with them.
But then again, what would be a good amp to power those monster towers? And no bi-amping....?
Originally Posted by 4DHD  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22984171
Synergy is one of those snake oil terms. It has no real meaning other than that the subjective impression is that it is compatible with the other equipment. I'm certain the OP could certainly find better speakers, even three way ones, from a company that specializes in speakers. There are exceptions, such as Sony which makes $27,000 high end speakers, but generally most companies building receivers don't build very good speakers.
Originally Posted by SonomaComa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22984787
Will you be using a subwoofer?  I strongly recommend it for movies or you will be missing a lot of the low frequency content. Speakers with puny 8 inch 'woofers' are not going to play at 115dB at 20Hz (reference) are they? ;) A sub is purpose-designed to do one thing well: reproduce bass.
And if you are going to be using a subwoofer, then you don't need big towers at the front. All you need are good speakers that can play well down to your crossover point - say 80Hz. Much smaller speakers can do that very well indeed - and because the hardest thing in speaker design is to make them play the bottom few octaves, it makes the speaker very expensive to even attempt it. So getting good satellite speakers will save you money, or you will get far better speakers for a given budget.
Passive biamping is just a waste of money - check the link I posted before. Biamping requires active (powered) crossovers before the speaker. If you tried to use active XOs with your speakers you would first have to remove the passive XOs inside them. Not a good idea.
Originally Posted by Theresa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22984806
+1. Totally agreed. And, for HT use, they are not even the best design IMO. Towers are not really needed for HT with a sub in place. Can't really see the point of picking an AVR and then letting that influence speaker choice.
(Actually, Pioneer have some kickass speakers out nowadays - but again, it's another exception. Yamaha have no credibility in speakers - well maybe the NS10s for studio use - but even they are often reviled).
Here's a review of the Andrew Jones-designed Pioneer BS41s .  Wow - get me - quoting reviews from Stereophile! .
Originally Posted by Theresa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates/0_50#post_22984806
Says you...then you exception Sony and this guy exceptions Pioneer. I would not buy either. And there are amp/AVR brands I would never mate with my high end JBLs...cos those brands just don't cut the mustard. Talk about leaving much to be desired!
So, YES, there is a difference.
Originally Posted by kbarnes701  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates/0_50#post_22984928
The only real exception, imo, is Harman, for speakers, amps, pre/pros. As for if towers are needed in a HT w/subs...I've walked into many a room that had speakers that were quite less and I could tell what I was not hearing...good mid-bass. B/C the speakers lacked anything I would call bass drivers....mid-bass or otherwise.
Originally Posted by 4DHD  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22985093
For cheap speakers the Pioneers are good, but they are not great speakers IMHO.
Originally Posted by Theresa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22985135
Yes - good for the price. But not 'good' as such.
But back to the point of this thread...if the OP wants Yamaha speakers, who are any of you to try and talk him out of those?
The subject is an AVR or separates. Personally for the speakers in question, I would not spend the money for separates. Maybe add a stereo power amp later, if he thinks its necessary. Of coarse, that means getting an AVR with pre outs for at least the L/R.
Do I think separates are better than an AVR, yes. I have a good avr, but my analog pre-amp is quite a bit better, especially for stereo playback.
Discussion Starter · #15 ·
I was planning on using a sub with those NS-777 towers. Never considered the Pioneers as I have heard them. But kbarnes701 suggested some higher end bookshelf speakers since I plan on using a sub. The speakers are about $900.00 a pair. The frequency response is rated at 30hz - 35khz. What bookshelf speakers for $900.00 would fit that bill and be able to reach those highs? And since I did plan on using a sub I was even thinking about the NS-555 floor speakers with the same tweeter, 5" midrange, and two 6 1/4" woofers instead of the two 8" woofers.
It's just that I have heard really good tower speakers that sound excellent with music but when it comes to HT applications the dialog in movies or even regular TV just does not sound right, to boxy. That's why I was thinking of using these 3-way speakers with a nice powerful amp to get things really boomin'. But now I'm wondering if I might get a better effect with smaller speakers and a sub. I just don't want and try and make the sub reach any of the higher octaves where smaller speakers leave off.
Don't let them talk you out of the Yamaha speakers. Given my past experience with Yamaha speakers (outdoor speakers and the built in speakers on my son's $1000 Yamaha keyboard), I would have no problem giving these a try. These would be higher on my list than other commonly recommended budget speakers (Infinity Primus, Pioneer, Polk Monitor, etc). If you end up buying them, please post a review. I get tired of the same old recommendations in this price range.
Regarding receivers, I had exclusively bought Onkyo/Denon receivers for the past 5 or 6 years (largely based on all the praise heaped upon Audyssey in these forums), but I recently switched to Yamaha (A3010) due to reliability issues with Onkyo. I have used the pinnacle of Audyssey (XT32), and I know it's the best room correction on paper. Maybe I have lousy ears (it's hard to compete with kbarnes' GIANT ear), but I couldn't hear a difference between Audyssey and YPAO in my home theater. Frankly, I thought both did a great job.
Discussion Starter · #17 ·
Yea, I do like the way those Yamaha's sound. And that was on a 100 wpc sherwood receiver. I keep hearing about all of the glory stories people tell when they get a nice new powerful amp. And that was what the original question was here. What is a good powerful receiver for those 6ohm 3-way tower speakers? Sensitivity is only 88 dB/2.83 V/1 m and the Input Power (Maximum / Nominal) is 250W / 100W.
Originally Posted by SonomaComa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates/0_50#post_22986850
Besides a Yamaha AVR, you have HK, Marantz, Denon. But you want to look for one with pre outs. At least for the main L/R towers.
And that usually means the higher priced AVRs in any brand lineup. Which will also have the bigger amps onboard. Which is a catch 22 kinda thing...the cheaper AVRs with the smaller amps don't have pre outs to connect a power amp. And those are the ones most likely to need an amp.
So if you think afterwards the Yamaha speakers need more power, then you buy a bigger stereo power amp.
Discussion Starter · #19 ·
That would be a great idea too. Then someone could have all the bells & whistles with something like a Pioneer Elite and then blast it with extra power. If and when I do upgrade sometime down the road I would like it to be the speakers and not the whole entire set up.
Originally Posted by SonomaComa  /t/1459058/not-sure-what-receiver-is-good-enough-possible-separates#post_22990760
Look, if you're after great audio, the most important components are the room and the speakers and how they interact with each other relative to the listening position.
Don't waste your time trying to get opinions on receiver A vs receiver B or the external amp crap. You'll get way more benefit from addressing the above.
Read the amplifier FAQ linked at the top of this section it'll give you a great idea of what you actually need.
Also go to the "audio theory set up and chat" section and do some reading on room treatments and EQ.
If I were you, I'd look for what features I need in an AVR, how much power I need for my speakers & room per the FAQ, how much I want to spend and then get the AVR that meets those criteria with the best room correction available at that price point.
  • Like
Reactions: JD in NJ
1 - 20 of 103 Posts
