1 - 10 of 10 Posts
I currently have an Onkyo 5.1 reciever that is able to do DTS and Dolby Digital, however it lacks the new formats (Dolby® TrueHD and dts®-HD Master Audio) would it be worth it for me to spend 200 bucks and upgrade to a reciever that can decode those formats?
I have a 5.1 setup with midrange level of speakers.
Thanks for any advice
Going back and forth between lossy and lossless audio never really wowed me like I thought it would. However, going back to listening to a lossy codec after hearing nothing but lossless for an extended amount of time showed me how much better the lossless was.
+1
Thats how it was for me, initially, switching back and forth at first I couldn't tell much difference in listening. But now that I have been listening to the HD Formats, going back and listening to it thru digital coax or toslink I can definitely hear a difference and like the sound of the HD formats on bluray thru proper equipment much more.
The HD formats tend also to be mastered with more dynamic range, so they sound much better on a capable system.
IF your AVR is able to handle and process DTS at 1.5M and DD at 640K via optical/coax, then you'll be pretty well set. Those are the usual 2 audio streams you will get from a BD disc via SPDIF.
But I'd suggest you not overlook other benefits of upgrading your AVR, like vastly improved DACs and EQ/setup systems in the newer AVRs as well as other improvements.
Discussion Starter · #7 ·
I agree, I would like one that can do HDMI switching. in the 200-300 dollar range do you think Sony, Onkyo or Denon make the better reciever (or other)
Discussion Starter · #9 ·
Originally Posted by javygonx /forum/post/19545607
For $200-$300 range; the only way to go its to get Onkyo 508 for $249; 608 model can get for $369 in newegg. Can decode TrueHD, DTS-MA; plus have HDMI 1.4 if you need to upgrade to a 3D TV in the future.
I ended up getting an open box Denon AVR 591 at best buy for 249. Great deal and I love the receiver.
For that price I would have recommended a refurbed Harman Kardon AVR 2600 or 3600 through eBay factory store (seller - harmanaudio). I used to have Denon receivers before and then auditioned an Onkyo and a HK. HK was much better for my ears. I ended up keeping the HK. Their customer service is top notch too.
1 - 10 of 10 Posts
