1 - 2 of 2 Posts
· Registered
hi,
im having this problem for ages. i have tried all possible drivers/decoder/renderers/etc and none of them works for me.
no synchonisation with display, as a result droping frames.
i use 9500GT videocard. if i set its output to 23Hz or 24Hz and go without reclock result is horrible on 23.97Hz movie, droping/doubling a frame every few seconds. if i use reclock, it happens at movie start every few seconds but then goes away and drops frame every 5minutes or so.
i have tried using CUDA decoder to be sure CPU is not loaded (under 10%) nothing helps. renderer reports frames is droped earlier in the chain.
the best result i can get is if i reclock movie to 25Hz and set video output to 50Hz, but still drops a frame sometimes.
can someone come up with any idea? anything.. feels like i have tried all besides throwing videocard out of window
· Registered
Hi miks
i used the gt9500 (gigabyte) for over a year (now using gt240) and never got problems
i use xbmc (windows) or mpc-hc (+reclock for automatic refresh change, using displaychanger )
and the automatic refresh was always set correctly. I NEVER go to change refresh to control panel
make sure you use latest nvidia driver, latest mpc-hc and latest beta reclock
BHH
1 - 2 of 2 Posts
