LOL...par for the course over there.I had to take a look at the Nvidia Shield forum over at Nvidia, and already, ungreatfulness.......
Set your Shield output to match the source resolution which means you have to do it manually, e.g. switch 4K when you playback anything 4K and switch to 2K when playback 2K video.How do I make sure my upscaling or processing on blu ray rips on my shield is not being handled by my shield and instead is passed through and letting my tv handle it (a much better Z9D)?
The "Basic" setting disables AI Upscaling.I am not seeing where to set this manually or turn this off. This is the only option on the screen (pic below). Can you tell me what I need to pick for the tv to do all upscaling and not the shield View attachment 3108012 View attachment 3108013 View attachment 3108014 View attachment 3108015
From the frontpage of the Plex app, enter the settings via the gear icon at the bottom of the sidebar. The last row of settings at the bottom before the "About" icon include "Refresh Rate Switching" and "Resolution Switching."Ok thanks-I’m with you so far. So I want to put in on basic. Then in Plex (which I use) can you tell me what setting exactly I should disable or enable to let it pass through to tv scaling to complete this process?
thanks again!
No. Never basic. That is the worst upscaling algorithm. A lot of the cheaper streaming devices only do basic. You either want enhanced or AI. I recommend you fool around with your AI low default and high settings and compare that Enhanced.Ok thanks-I’m with you so far. So I want to put in on basic. Then in Plex (which I use) can you tell me what setting exactly I should disable or enable to let it pass through to tv scaling to complete this process?
thanks again!
As long as your display is it better upscaler then then shield, then this is your best route for local content only. Setting you're a Plex to match resolution and frame rate... and then your TV will upscale the resolution Since plex is smart enough to override the frame rate and resolution settings that you're shield is set to.Ok. And which should I turn on or turn off in order to let my Z9D (tv) DJ the upscaling and the plex leave things alone?
I’m guessing that’s the best route if you have a really good tv that would better upscale...
Let the Shield do the upscaling. I have the same video processor in my Sony as your Z9D and I found both the Shield and ATV4K do as good or better upscaling than our TV’s do. Simple is better too.Ok. And which should I turn on or turn off in order to let my Z9D (tv) DJ the upscaling and the plex leave things alone?
Thanks but I don’t necessarily want basic-I want upscaling OFF so my tv (which is superior in upscaling -Sony Z9D) to do all the upscaling.No. Never basic. That is the worst upscaling algorithm. A lot of the cheaper streaming devices only do basic. You either want enhanced or AI. I recommend you fool around with your AI low default and high settings and compare that Enhanced.
What others have said, Since you have your shield set to output 4K., your upscaling will only happen when outputting 2K source as 4K.
-T
Ok, in that case how would I make sure my Z9D isn’t being redundant and also upscaling, how would I turn the upscaling OFF on the Z9D...just don’t want BOTH to upscale.Let the Shield do the upscaling. I have the same video processor in my Sony as your Z9D and I found both the Shield and ATV4K do as good or better upscaling than our TV’s do. Simple is better too.
It won’t. If you have the Shield set at 4K the TV can’t upscale any more than that. You’re good.Ok, in that case how would I make sure my Z9D isn’t being redundant and also upscaling, how would I turn the upscaling OFF on the Z9D...just don’t want BOTH to upscale.
...sigh...that isn't how this works with the Shield's implementation. The basic setting is the standard or normal setting. This is the only way to avoid having the Shield doing additional processing if you want to avoid it. It isn't an "upscaling algorithm." It is the baseline mode. Enhanced and AI are the options utilizing an upscaling algorithm.No. Never basic. That is the worst upscaling algorithm.
Just an FYI there is a dedicated forum for the 2019 Shield models. This forum was created for the older models and while there has been plenty of overlap between the two forums, you'll find more info related to the 2019 refresh in that forum.Ok, in that case how would I make sure my Z9D isn’t being redundant and also upscaling, how would I turn the upscaling OFF on the Z9D...just don’t want BOTH to upscale.
Don't sigh me....sigh...that isn't how this works with the Shield's implementation. The basic setting is the standard or normal setting. This is the only way to avoid having the Shield doing additional processing if you want to avoid it. It isn't an "upscaling algorithm." It is the baseline mode. Enhanced and AI are the options utilizing an upscaling algorithm.
