I've got a Decco amp, with a Motorola cable box about 6" above it, a Samsung 1600 BR player above that and a Samsung A850 above that.
Before I put in the cable box, the Decco remote worked fine. Now, when I turn on the cable box, it blocks out the Decco remote for about 15 minutes. I turn on the Decco, set the input I want and turn up the volume. Then I turn on the cable box and tv. This results in the Decco remote not working -- for about 15 minutes. After a wait, it works fine -- although on some occasions it will later cut out for a bit, then come back.
I'm guessing that there is some interference from the cable box, and I just have to live with it.
Odd, though. Odd.
Odd, though. Odd.
