I like the new layout because it could improve the sightlines pretty simply. Depending on your future desires for screen size, you could potentially build out a faux wall a bit closer to the ceiling, to work around that roofline.
Try both and see what you prefer. Have someone hold it up.Should I mount the center channel above and angle it down or below and angle it up?
Have you measured the average seated height of a viewer, then tried to center the TV at that height? I'd measure that out, to determine optimal viewing angle, then see if the upper or lower end has more room for the speaker. I'd hate to mount the screen too low, to fit the center channel, then find that you have a crik in your neck after watching movies.Should I mount the center channel above and angle it down or below and angle it up?
Just took a measurement tv center would be at about 39" viewer eye height would be 40-41" so pretty close if I mount the tv right on the edge of the angled ceiling. Viewing distance would also be right in the optimal range of 10' away from the TV. I would have to find away to mount the heavy emotiva C1+ center channel above the tv like below.Have you measured the average seated height of a viewer, then tried to center the TV at that height? I'd measure that out, to determine optimal viewing angle, then see if the upper or lower end has more room for the speaker. I'd hate to mount the screen too low, to fit the center channel, then find that you have a crik in your neck after watching movies.
YMMV, but I think it's easier to point a speaker than a viewing screen.
Yup, I agree, those are solid numbers. You might consider sticking a black piece of construction paper (or similar) up there, to see if you find it distracting?Just took a measurement tv center would be at about 39" viewer eye height would be 40-41" so pretty close if I mount the tv right on the edge of the angled ceiling. Viewing distance would also be right in the optimal range of 10' away from the TV. I would have to find away to mount the heavy emotiva C1+ center channel above the tv like below.
Lower is a much easier mounting option guess Ill try it out.Yup, I agree, those are solid numbers. You might consider sticking a black piece of construction paper (or similar) up there, to see if you find it distracting?
As a rule, I want to say that I see primarily "lower placed" center channels, but I'm not sure if it's aesthetics or performance?
Agreed. Heck, you can always do the college "put it on a stack of books or a cinderblock" to test it out.Lower is a much easier mounting option guess Ill try it out.
