Status
Not open for further replies.
1 - 4 of 4 Posts
I own an RCA P61300. Can anybody get me started receiving HD programming off the air? I already get DirectTV, but I'd like to be set up for the local HD programming.
Thanks in advance,
Scott
We need more info . . . what DirecTV receiver do you have? It it is not an HD model, then you should probably upgrade to an HD model and get HBO-HD for starters . . . it is probably some of the best HD available. If it is HD, then you need to add a terrestrial antenna.
Welcome Scott
http://www.hdtvgalaxy.com/broad.html has a list of operating stations ( there are probably other sites with similar info). If you're close enough all you need is an antenna pointed at the transmitter - your TV has a HD tuner built-in , right? Read the threads (use the search function) on antennas to get informed about them, range, height, design etc...
Andy
1 - 4 of 4 Posts
Status
