You won't eliminate the judder until you have 1080P/24 input (which XBR2 won't do) and the set showing it in some multiple of 24 (i.e., 72, 96, or 120).
Originally Posted by yet2b /forum/post/0
XBR1 SXRD's scale to and display _everything_ in their native 1080p resolution. They can't do anything else. I can see how you might have thought this would also mean the XBR1 would accept a 1080p signal. But, consider that there simply were no 1080p broadcasts (still aren't), and that it is easier to design electronics to process 1080i. Given these factors, Sony did the smart thing in not trying to make give the SXRB1 1080p input capability. In fact, probably the only reason the A2000 inputs 1080p is that Sony is trying to tie it to the BluRay DVD. At this point, the benefits of inputting 1080p are non-existent for everything except computer monitor use.
Something I would like to see is a better way of dealing with judder. I find 2/3 judder on an HD TV very annoying. If the 2.5 DRC of the XBR2 provides any improvements in this area, that would be why I would want it, not because it can accept 1080p signals.
In your case, after attempts to fix the problem, you still have the green blob. You probably should push for an exchange with the A2000 or XBR2 on that basis.
