It’s great to read this that you’ve found settings that further increase image quality. I know we’ve talked before that you don’t use HDR and SDR game modes, but would you do us a favor by doing an accurate calibration on it too, because I’m planning to get the Play Station 5 and I’d be happy to have a fresh HDR - SDR settings for game modes.Further adjustments to the SM White Balances got the 2 Point almost down to all zeros tonight
Tomorrow, will fine tune and complete some of the further calibrations. Takes about a week to get everything completed.
Looking good !
I have never had the TVs calibrated. The set is working great(other than no TV Plus), but I wonder if there could be any improvement in picture quality by restoring the tv to its original settings and performing the initial setup again. Or do the risks of doing this out of warranty outweigh any minor picture improvement?Just like a new, much improved TV after the following:
# 1 Did a SM SVC Reset
# 2 Adjusted the SM White Balance Offsets and Gains to give better Normal Menu 2 Point values after calibrating
# 3 Complete re-calibration
# 4 Will wait a few days for values to settle down and fine tune
Colors more vivid, and solid. Much better sharpness. As previously mentioned, this set continues to improve PQ wise with each new calibration. Will continue to try to get set to were the 2 Point Values are all almost all Zeros.
Problem when trying to set the SM White Balance for the Normal Menu 2 Point is the set going into Dynamic Mode for the SM and returning back to Normal viewing. It heats up the panel, which in turn throws off the scans. Will have to do one step at a time now that the major changes have been done.
2 Point before the above: -25 / 1 / 5 : -12 / 0 / -5 After - Current results: -2 / 0 / -6 : 1 / 0 / 3 (Work in progress)
So let's make this clear how is it? I know all the settings in the service menu. Do I overwrite these values with white balance for all image modes? So, for example, does this result in an improvement in both SDR-HDR game mode and movie mode? How is it now I do not understand exactly.Note: DO NOT GO INTO THE SERVICE MENU IF YOU DON'T KNOW WHAT YOU"RE DOING !!!
Secondly, this was the SM White Balance Factory Default values:
128 128 128 123 128 143 resulting in the last calibrated results: of -25 / 1 / 5 : -12 / 0 / -5. If your results were not close to these results, then the new settings will not do your set any good compared to mine..
Intermediate results: 132 128 134 111 128 138 resulted in: -2 / 0 / -6 : 1 / 0 / 3
Current results: 132 128 132 112 128 137 resulted in: -2 / 0 / 0 : -1 / 0 / 3 - so much better.
Back in the old days, White Balances and 2 Point were almost click for click in step. No longer, plus what goes up in one may go up or down in the other - why you cannot eyeball it !
Yep and my newer model won't be a Samsung just because of their poor customer service and write-off of current owners.Samsung doesn't give a hoot after a set is over 2 years old - their response - buy a newer model !
