P
"OFFICIAL" 2019 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8)
Jump to LatestFollow
4221 - 4231 of 4231 Posts
212 of 212
P
pana3000
Joined Jul 21, 2018
#4,221 •
1 d ago
jdsmoothie said:
You can use either a Firestick or Roku.
how about an android box? will that work also?
Reply Quote
J
jdsmoothie
Premium Member
Joined Sep 28, 2007
Discussion Starter •
#4,222 •
1 d ago
Yes.
2020 Denon AVR Owner's thread
2020 Marantz AVR Owner's thread
Reply Quote
Like
J
johjames912
Joined 11 d ago
#4,223 •
23 h ago
Is the Denon AVR-X2600H receiver's internet speed capped at 100mbps please?
I haven't been able to find any information in the user manual. I ask as my wifi router states that the LAN speed to the receiver is 100mbps and so I wondered if I have a faulty device or router, or if this is the norm. Thank you.
Reply Quote
Like
D
deano86
Joined Apr 11, 2008
#4,224 •
22 h ago
Why would that be faulty? Your Denon can only stream audio files through its network connection and if it indeed has the older style 10/100mbps LAN port, that is way more bandwidth capability than is needed for that purpose. I assume your router has gigabit LAN ports and you have a direct connection to it? .. .thus your question?
For Sale! OEM bulb assy for Panasonic PT-AE8000 projector.
Panasonic ET-LAA410 OEM bulb assy with filters and...
Reply Quote
Like
D
DGD123
Joined Mar 28, 2017
#4,225 •
22 h ago
Agreed, I don't believe my Denon receiver has a 'bandwidth test' as it's requirements for HEOS aren't much above 20Megs. That said, I do see some small 5 or 8 port switches that are not gigabit in capability.
Reply Quote
Like
J
johjames912
Joined 11 d ago
#4,226 •
19 h ago
Thank you Deano86. I use, as you correctly assumed a gigabit router and it is directly connected to the receiver. My question was less about whether a 100mbps connection is sufficient and more whether the Denon AVRX-2600H is restricted to that bandwidth. An academic question if you will! Do you know if the Denon AVR-X2600H has the older style LAN port? That would explain the issue.
Reply Quote
Like
J
johjames912
Joined 11 d ago
#4,227 •
19 h ago
Thanks DGD123.
Reply Quote
Like
D
deano86
Joined Apr 11, 2008
#4,228 •
19 h ago
I would guess it is... My Denon is obviously older than yours a 2014 ( AVR-X5200W) but yes, on the LED display of my TP-Link gigabit switch it does show that mine is connected at 100mbps port speed as well... There really is no need for a gigabit capable LAN port on a device that only streams audio anyway... but I assume your model also has wifi capability too, and I have no idea what those specs would be..
Reply Quote
Like
C
chronomac
Joined Jan 11, 2006
#4,229 •
18 h ago (Edited)
Does this receiver support 120hz at any resolution? Didn't think to try it out until tonight and my PS5 doesn't show it as a supported mode in 1080p or 4K. I might need to restart it, though.
I checked back about 20-30 pages and didn’t see anyone else ask.
If not, it's not a deal-breaker. Just curious, mainly.
Reply Quote
Like
C
chronomac
Joined Jan 11, 2006
#4,230 •
16 h ago
Welp, nevermind. Found this in the PDF manual (page 231):
Reply Quote
Like
J
jdsmoothie
Premium Member
Joined Sep 28, 2007
#4,231 •
15 h ago
No, rather only on the current 2020 models with HDMI 2.1.
Reply Quote
Like
P
pana3000
Joined Jul 21, 2018
#4,232 •
a moment ago
so after checking and rechecking all my settings the only time it worked properly was when I first got the receiver and also when I did a hard reset on both the Denon and the TCL tv and adjusted the settings then and then it lasted for 2 weeks. I have an extended warranty that covers the receiver but I'm wondering if it's worth bringing the Denon in and having it checked out? the retailer that sold it to me told me they could have the service manager check it out then if that fails, send it off to denon/repair to have it thoroughly serviced or checked. If that fails and it's faulty, then either replace with the same model if still available or trade up to a comparable one for thisyear. This means Im out with the receiver for 4 weeks. Worth it? advice? maybe I should just set up the tv as a monitor and be done with it.
