Monitor Asset Manager Report, generated 2/2/2012
Copyright (c) 1995-2011, EnTech Taiwan.
Monitor #1 [Real-time 0x0041]
Model name............... MTC26T42
Manufacturer............. Mitac
Plug and Play ID......... MTC0B01
Serial number............ 1001
Manufacture date......... 2008, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 700 x 390 mm (31.5 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.652 - Ry 0.333
Green chromaticity....... Gx 0.275 - Gy 0.595
Blue chromaticity........ Bx 0.143 - By 0.063
White point (default).... Wx 0.285 - Wy 0.293
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 14-91kHz
Vertical scan range...... 22-80Hz
Video bandwidth.......... 160MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Standard timings supported
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 2
Detailed timing #1....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.030 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #2....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Detailed timing #3....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #4....... 720x576p at 50Hz (16:9)
Modeline............... "720x576" 27.000 720 732 796 864 576 581 586 625 -hsync -vsync
Detailed timing #5....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
720 x 480p at 60Hz - EDTV (16:9, 32:27)
1280 x 720p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
1280 x 720p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
1920 x 1080p at 50Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1920 x 1080p at 25Hz - HDTV (16:9, 1:1)
1920 x 1080p at 30Hz - HDTV (16:9, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48/88/96/176/192 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 205MHz
Report information
Date generated........... 2/2/2012
Software revision........ 2.60.0.972
Data source.............. Real-time 0x0041
Operating system......... 6.1.7601.2.Service Pack 1
Raw data
00,FF,FF,FF,FF,FF,FF,00,36,83,01,0B,E9,03,00,00,01,12,01,03, 80,46,27,78,0A,19,90,A7,55,46,98,24,
10,49,4B,01,08,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01, 01,01,01,1D,00,72,51,D0,1E,20,6E,28,
55,00,C4,8E,21,00,00,1E,01,1D,80,18,71,1C,16,20,58,2C,25,00, C4,8E,21,00,00,9E,00,00,00,FC,00,4D,
54,43,32,36,54,34,32,0A,20,20,20,20,00,00,00,FD,00,16,50,0E, 5B,10,00,0A,20,20,20,20,20,20,01,9A,
02,03,22,72,4D,03,84,05,07,10,12,93,14,16,1F,20,21,22,23,09, 7F,07,83,01,00,00,67,03,0C,00,10,00,
98,29,8F,0A,D0,8A,20,E0,2D,10,10,3E,96,00,C4,8E,21,00,00,18, 01,1D,00,BC,52,D0,1E,20,B8,28,55,40,
C4,8E,21,00,00,1E,01,1D,80,D0,72,1C,16,20,10,2C,25,80,C4,8E, 21,00,00,9E,8C,0A,D0,90,20,40,31,20,
0C,40,55,00,C4,8E,21,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E, 96,00,C4,8E,21,00,00,18,00,00,00,37
Hardware data
BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI000 18.PCI0001C
00000000 = 01048086.20900006.06000009.00000000.00000000.00000000.000000 00.00000000
00000010 = 01168086.00900407.03000009.00000000.F7800004.00000000.E00000 0C.00000000
000000B0 = 1C3A8086.00100006.07800004.00800000.F7F0A004.00000000.000000 00.00000000
000000D0 = 1C2D8086.02900006.0C032004.00000000.F7F08000.00000000.000000 00.00000000
000000D8 = 1C208086.00100006.04030004.00000010.F7F00004.00000000.000000 00.00000000
000000E0 = 1C108086.00100007.060400B4.00810010.00000000.00000000.000202 00.0000E0E0
000000E8 = 1C268086.02900006.0C032004.00000000.F7F07000.00000000.000000 00.00000000
000000F8 = 1C498086.02100007.06010004.00800000.00000000.00000000.000000 00.00000000
000000FA = 1C038086.02B00007.01060104.00000000.0000F0B1.0000F0A1.0000F0 91.0000F081
000000FB = 1C228086.02800003.0C050004.00000000.F7F05004.00000000.000000 00.00000000
00000200 = 816810EC.00100407.02000006.00000010.0000E001.00000000.F00040 0C.00000000
00000300 = 08858086.00100406.02800067.00000010.F7E00004.00000000.000000 00.00000000
00000600 = 01941033.00100406.0C033004.00000010.F7C00004.00000000.000000 00.00000000
01040000 = 00FFFFFF.FFFFFF00.3683010B.E9030000.01120103.80462778.0A1990 A7.55469824
00000020 = 10494B01.08000101.01010101.01010101.01010101.0101011D.007251 D0.1E206E28
00000040 = 5500C48E.2100001E.011D8018.711C1620.582C2500.C48E2100.009E00 00.00FC004D
00000060 = 54433236.5434320A.20202020.000000FD.0016500E.5B10000A.202020 20.2020019A
01040100 = 02032272.4D038405.07101293.14161F20.21222309.7F078301.000067 03.0C001000
00000020 = 98298F0A.D08A20E0.2D10103E.9600C48E.21000018.011D00BC.52D01E 20.B8285540
00000040 = C48E2100.001E011D.80D0721C.1620102C.2580C48E.2100009E.8C0AD0 90.20403120
00000060 = 0C405500.C48E2100.00188C0A.D08A20E0.2D10103E.9600C48E.210000 18.00000037
