I agree, it doesn't make sense.
Be sure to try it with several CDs, SACDs, Blu-ray disks -- some CDs, especially, are harsh, so a neutral speaker should sound harsh with them. On Rock or Metal, especially, the deep bass is often turned down or compressed to give them more room to blast during the protracted "loudness wars," making the CDs out of balance, meanwhile, sometimes turning up a part of the highs. Google "The Missing Octave" and his other stuff to see Chris A's studies of this. Most, but not all, classical or jazz disks don't have this problem.
I am only truly familiar with the older B&W speakers, but harshness is the last thing I would expect from them. The Stereophile anechoic graph [their figure 4] doesn't show a problem with yours. Bowers & Wilkins 702 S2 loudspeaker. Besides, Audyssey "FLAT" is supposed to flatten out the curve, which, customized for your room, should make a speaker without big dips, but a few peaks, less harsh.
How close are you sitting?
Maybe, if your room is very live, Audyssey can't handle the reflections, but I doubt it.
Try what Feri suggested. A bad mic is a possibility, but I don't get why so many Audyssey mics (which you must use) fail -- I have been around many mics, including some cheap ones, and none has ever failed.
