What are you using to measure the SPL?Sorry, if it's been pointed to before. But is there a 4K Calibration Blu-Ray that has the required test tones to check each individual level of my speakers. I was corrected to not use the test tones in the Denon X4500 amp as they bypass the Audyssey settings.
I also re-ran Audyssey setup (was surprised that they updated it, at least the screens and walk-through probably in one of the firmware updates) and my 9.1 Atmos setup now sounds totally different. I agree, I will wait a week to let my ears settle in but I think it does sound a bit more like the theatre even though it may be a bit muffled from what I'm experienced to. But I probably mucked up the settings before anyway.
I do have the Disney WOW DVD and wondering if it was any good. I've looked on Amazon for any others, but the other seems to be rated for pros with really no documentation. I guess what I'm looking for (because my Sony OLED was professionally calibrated already) is just something that will put out standard reference tones.
Maybe there is a link to an .iso that I can create a DVD that outputs the tones?
Thanks in advance.
Do you have a laptop with HDMI handy? If so, download REW and use it's tone generator (specifically, Pink Noise @ -30dBfs).
Otherwise, you can find some good test tones here.
EDIT: AFAIK, the WOW disc should work just fine for you. Just remember that the LFE (subwoofer) test tone on the WOW disc will be +10dB higher than the others. Also, AFAIK, there are no Atmos test discs yet that will send tones to the Atmos speakers, but that may have changed recently.
