I'm having some issues with calibrating the p60 and was wondering if you guys could give me some insight and take a look at my charts. I have FW 1.1.19 and am working on gray scale for daytime viewing using the calibrated picture settings. Gamma is set at 2.2 and target ftL is 50. On the TV, auto brightness is set to off, color temp is normal, active led is off and so is clear action.
I'm using HCFR with a colormunki display and GCD disc. I didn't have any issues with the 2 point adjustment (pics attached) I used the 80/30 patterns to set it. My issue is with the 11 pt settings. I can't seem to get my target gamma levels that HCFR shows in my y value to match. For example, in the the 70% adjustment my target y is .326, I can adjust the RGB to get to that y level on measurement but then my dE levels are out of whack. When I try to adjust them down, my y level bumps up to .329 which puts the gamma off. Not really sure how to get those two numbers to equal out. Any suggestions? Thanks much.
