27381 - 27400 of 27410 Posts
Premium Member
what you planning to move too Frank ?
Maybe back too Anthem AVM 60
edit : then again the Marantz is getting the DTS X Pro upgrade. Will think about it.
hi all, i'm from Italy and I have a denon avp a1hd, the biggest problem I notice is only with the dolby Digital plus of Netflix and Amazon prime, the central channel is distorted with many sibilants to the voices(pitch sound). I also tried to change blu ray player but the problem persists. Does it happen to you too? is there any solution? Thanks
bonasera
centre channel issues are well reported with this model
I’d say the capacitors are on the way out from overheating based on the stupid decision to stack all the boards horizontally with poor air circulation
better to replace the caps BEFORE they fail totally and cause non fixable problems
cinemike in Germany used to repair these but I don’t know if he still does
if you do ship it for repair ship it on a pallet
thanks for the answer, but I think that if the capacitors are broken this problem should always do it with all the tracks and also with the physical supports I think, and not only with the Dolby Digital plus, don't you think?
I only watch movies any way in my theatre so I don’t think I will even upgrade. Too be honest I might even sell the unit as I don’t need the xtra channels. I don’t even use the other options as well.
Congrats on the new Trinnov, mate. Bet it sounds fantastic in the FraninMAX. I know you mentioned putting your old 8805 in the master bathroom. How'd that go? The AVM60 would make a nice garage system. Kicking back in the garage with a Fosters, tunes on the Anthem, shrimp on the barbie. Come at The Franin, 2020.
Premium Member
Thanks Waboman. I forgot to mention I had to use my datasat as a boat anchor. Something had to keep my little Tin boat from floating away
  • Like
Reactions: alebonau
Sorry I misread ur quote , I thought it was a general thing
i had sound issues in Netflix from my tv and then used Netflix streaming from my iPad app and nOw sound is perfect . I
What about the Nad M17v2 as a replacement for the AVPA1HDA? Anyone considered this?
I'm glad you found a good use for your Datasat. They do make a right proper boat anchor.
Premium Member
Definitely lodged in between my old 8802 and an old Yamaha pro logic receiver.
Sent from my iPhone using Tapatalk Pro
That's some serious anchorage. Your boat ain't going nowhere!
Premium Member
It’s a tin boat. It aint going anywhere. Great attraction to the sharks
Amazing how time changes everything.....when I sold my house in 2018, I just left the AVP and POA there.....I got old and couldn't lift them anymore and I just didn't want to deal with it. Left my Definitive towers there also....oh well.....looking back, I should have taken the speakers and the POA.
  • Like
Reactions: alebonau
There is an unused AVP on Ebay that I'm thinking of biding on. But, I don't believe Denon is supporting software updates for the AVP any longer. Does anyone recall what improvements were made available by software updates?
Not sure how to put a question on this forum. I still use my A1HDCI still works great and sounds amazing. However, I can no longer connect to the Denon Server through the firmware selection. I know it is old and no longer supported but I was told there is a firmware update for CEC that allows HDMI pass through. Can anyone help me with this.
good evening, i have an avp without xt32, what kind of recent microphone could i use for calibration? the original dm-505z is now unavailable.
