20521 - 20540 of 21072 Posts
Banned
I think it's like any sub that size, just a limited number of takers within a particular geographic area at a given time, especially one who would have to do what you don't want to do....as far as price I'd pay maybe $200 for something like that but you'd have to be pretty close. What area are you in? How about a friend who has the space and no sub to get them started?
what is a fair price to sell it?
I agree. $200-250 would be a great deal to the right buyer, but it may take a while to find him. I'd just advertise here and on craigslist. Someone will eventually buy it, heck, I found a buyer for my plate amps. I have 2 Empires running on my iNuke 6000 and they are phenomenal. I don't think I'll sell them until I move and build a dedicated theater with DIY 18" subs and speakers behind the screen...even then, they might end up somewhere else. I really like them and I really really like the enclosure materials. Such a great design.
I plan on buying a pair of HSU Research VTF15HMk2's.
Also, looks like SVS is having a sale this weekend, Dunno if you were considering them...I haven't looked at subs since buying my Empires.
If I were you, I'd buy a iNuke 6000 and shop for another Empire. :p Those VTF15HMk2's look nice though.
Owners Manual
Hi, looking for owner's manual for Epik Subwoofer, actually just a copy is all I need. Just not sure which model I purchased several years ago! Single 15" driver with single large port on front of fairly large cabinet. (18" W , 26" High, 26" deep) Lost item in move and unit has been on hiatus for maybe 8 or more years. If you recognize this unit or have the manual, I'd be happy to send you $10 for a copy.
Thanks, Bill
Well I finally found the picture of my sub - it's a Castle. So Epik never sent out any information or user manuals with their subs? That would certainly explain why I don't have one! Anybody have some info on my model? Thanks in advance.
General intructions. In the LFE setting, crossover is removed from signal pass and adj dial is inop? Proper use of phase control. How many watts is the amp? Do I pass the AC through my power conditioner or go straight out of the wall? etc.....thanks for assisting me.
My Epik plate amp is dead, so I'm considering a Behringer iNuke 3000DSP or some other external amp. Several folks here seem to be doing this. Can someone explain how I would convert the RCA subwoofer out connection on my Onkyo Receiver to the 1/4 inch phone input into the amp? Also, are you running the amp bridged, or one side only goes into the Epik? And what DSP adjustments are you making on the iNuke? I've removed the plate amp and disconnected the speaker cable, so I'm good with running those to the amp speaker cable connections, just need help with the rest. Thanks for your help.
Consider a wireless sub (bluetooth) link like the Rocketfish.
Banned
Hopefully someone with a Castle can confirm but if that used a similar plate amp to the Empire, the LFE input does bypass the lpf/crossover if you're using the avr for that (but you could simply turn it to max to be sure), proper use of phase control is simply trying both positions and seeing which gives you better bass but that will depend on your setup. Can't tell you specifics on the amp at all, supposedly the Empire amp originally was 600W, later replacement versions 500W. I don't use a power conditioner, don't see the need/purpose of one, some have been known to throttle amps if that's what you're thinking so maybe if you post up what unit you have over in one of the power conditioner threads you can get some info.
Thanks for your help. I'll make a go of it with that info. Awaiting all new gear to match up with my sub. Later.
Looks like the plan has changed. Found out since last posting my wife is 13 weeks pregnant with our first child. All large purchases have been put on hold. Ha. So... If i were to buy an inuke one would assume an inuke1000dsp should be plenty? or do i need to spend the extra 80 bucks on an inuke3000dsp? Also how noisy are the fans? i currently have a antec av cooler sitting on top of my Pioneer Elite SC-37 that i barely notice when everything is turned off, comparable?
Congrats on the kiddo! Pile up that cheddar and take care of Mama!
The iNuke fans are noisy. I wouldn't advise putting it in your theater room. (I have a rack in another room with all my theater gear).
The 1000 should be fine, much more power than the stock amp either way.
There are threads where people have replaced the fans with quieter ones with much success.
You can always buy a similar sized plate amp from Parts Express, but an actual amp is a better long term solution.
Premium Member
Hey guys would it be smart to buy a use Epik sub/s at this point in time?
I read here as a bad amp from the comments he can replace the actual amp plate?
What went wrong with this company, I was surprise this company went under in such short time.. Well not really important, just talking out loud.
Djoel
Banned
The epik empire have the amp issue. I don't think older subs have an issue. My conquest is still going strong.
Actually the Legend had more amp issues than the Empire. My Empire is still plugging along with daily use, although I did have an amp failure and was replaced by Epik while they were still in business.
@Djoel If the amp fails there are plate amp solutions but believe the boxes need modding a bit, been a while since I've reviewed, though. External amp with dsp probably just as cost effective and more useful (but would require a place in the rack and fans may need modding if noise is an issue). Epik would probably be around still had they sourced reliable amps.
My Valor is still going strong too. Never had an issue with it and still love it!
Epik Phoenix repair?
So my Epik Phoenix subwoofer died the other day. Just will not power on. I've had it for about 5 years and wondering if it's worth saving. Are there any amps that work with this or is there an easy way to check the fuse? I tried another power cable with no luck. Bummed as I remember spending about $1200 for this thing. Thanks.
Banned
Lots of amps will work, but if you want a matching plate amp that might be more difficult. Unlikely the driver is bad. I'd look at an external amp personally, something like a Behringer 3000DSP or 6000DSP. If there's not a fuse obvious on the outside of the amp you might take it off and check inside as well but not familiar with your particular model, don't believe my Empire amp has an internal fuse but it doesn't have an external one....
Ok I was going to take it in to a local electronics repair store. Once they most likely verify it's the amp, how hard is it to use the external amp with it?
