Ok plan B. So I've installed a replacement lamp, and I have the same problem. So if the issue isn't the bulb, is it worth spending any money trying to figure out what the problem is? Or should I say 11 years was a good long run for a front projector? If you are wondering what the image problem looks like is moire type display with weird colors. I wasn't quite sure I believed the "replace lamp" error message on the screen. Or it could have been a defective reproduction Epson kit with Osram bulb. Is it worth sending the projector anywhere to have some take a look? Or is there a diagnostic menu that I can try to go through?
If I'm looking at a new projector, I'd like to go laser and 4k. But from my brief reading, in order to get a projector that does everything well, it costs over $6k. Any ideas or recommendation? My screen is about 9ft wide with projector about 18 feet from the screen and sitting area about 13ft from the screen. Too lazy at the moment to get the tape measure out.
