So I just set up my Panasonic UB820 to the recommended settings, but it only seems to be able to put out a 1080p 24fps 12 bit YUV color space picture. I can’t seem to get it to send 4k.
I have 4k eshift set to on and original resolution set to Auto. In the setup hdmi menu, when I try to force 4k, it will do a test and revert back to 1080p.
Could this be a limitation of my 45’ monoprice cabernet active cable, or do I likely have something set wrong? Panasonic to Marant SR8012, Marantz to projector.
Edit: Hmm, when I connect the Panasonic directly to the 45’ monoprice cabernet, bypassing the Marantz, it goes into 4k 60hz 4:4:4 instantly. So it seems the issue is some setting or lack of pass through in the Marantz 8012.
Edit 2: After having the Panasonic directly connected and having success with 4k 60hz 4:4:4, then powering down and unplugging everything and routing back through the receiver, everything now works perfectly. Strange, but I’ll take it!
Edit 3: So when I turn zone 2 on in the Marantz to pass the original hdmi audio to my secondary receiver, an Onkyo TX-NR3010 that extracts front heights, wides, and two more subwoofer channels, I lose the 4k image and get a blank screen. When I turn zine 2 off, it comes back on in 4k. More work to do.
