4861 - 4880 of 6239 Posts
Originally Posted by serialmike /forum/post/20435955
Its a little hard to compare due to overseas versions having bravia3 which makes the ace work differently and worse as you can see fluctuation. Ace on makes our ex5's much better. Another thing I see is thier greyscale is way worse than what I got. Though I know exactly why. Mine used to look that way. Then I realized other tweaks that I could do to the white balance to get mine where it is.
He does seem to have a better gamma than mine but gamma really isnt an issue unless your way out.
Not to be cocky but looking at it, I know more about the set than he does when it comes to calibrating it. The reason is I spent alot more time. But I can tell there are things he doesnt realize about how the settings work. Normal white balance doesnt effect other things so he just did what you normally would do when calibrating. I found out the the white balance does effect things it shouldnt and I compensated and utilized these type of things when calibrating the set.
Thanks Mike, Well you have made your case as to why your settings are accurate. I will adopt them as they are the only ones in this thread that are industry standard and also among professional reviewers as well.
Greetings!
I just bought this TV today...and having a hell of a time getting greens and reds to populate properly so far..
more so, the TV is cropping too much (when, say, I play COD, I can not see the "bonus" that you get for getting a certain number of kills. both - xbox and tv are set to 1080p.. any solution to this? thanks in advance. (nvm, figured it out)... working on settings now. sorry.
Hi everyone,
Let me apologize in advance for not wanting to spend hours of reading this massive thread for specific answers. I'm considering to get an EX500 but I need to get confirmation from you owners on something...does this model exclude the all-too-common auto-dimming issue you see during dark scenes? I have a Samsung LN46D630 which has that issue unfortunately (which is odd because its 2-years-older B630 model didn't have that issue in Movie mode).
Please let me know soon and thanks in advance.
Originally Posted by FrostyCollects /forum/post/0
Hi everyone,
Your safe from that with the EX line...
If someone could post the original box dimensions I will be extremely grateful. I need the dimensions so that I can create a UPS shipping label. I know the shipping weight is 31 lbs (as per Amazon).
BTW, I'm assuming that shipping in the original box/packaging is safe enough? Or am I about to make a big mistake?
Thanks for any help
Thanks for any help
Hey man just measured for you, 7.5" x 29.5" x 52.5"
glgl
Ok I did some readings last night -
Eye-One LT Meter with AVSHD - 55EX500 set
SerialMike Settings
My settings -
My settings are serialmike old settings plus a few changes in white balance -
Picture Mode- Custom
Backlight-1
Picture-90
Brightness- 50
Color- 50
Hue- 0
Color Temp- Warm2
Sharpness- 0
Noise Reduction- Off
MPG Noise Red- Off
MotionFlow- Standard
Cinemotion- Auto2
Ambient Sensor- Off
Advanced Settings
Adv Contrast Enhancer-Low
Black Corrector- OFF
Gamma- 0
Clear White- Off
Live Color- Off
White Balance-
RR-Gain: -1
G-Gain: 0
B-Gain: 0
R-Bias: -1
G-Bias: -3
B-Bias: 7
Picture size-Full Pixel
Power Save-Off
Newest settings based off of Mikes last ones - 9-28-11
Gray scale(Average Gamma:2.23, contrast: 1798:1)
Eye-One LT Meter with HCFR. AVSPatterns
Backlight-1
Picture-82
Brightness- 50
Color- 50
Hue- G1
Color Temp- Nuetral
Sharpness- 1
MPG Noise Red- Off
Cinemotion- Off
Ambient Sensor- Off
Advanced Settings
Adv Contrast Enhancer-off
Black Corrector- off
Gamma- 0
Clear White- Off
Live Color- Off
White Balance-
RGain -2
GGain -3
BGain -39
RBias -1
GBias -2
BBias -1
Power Save-Off
Luminance -
Gamma
RGB
Color temp
CIE Chart
SerialMike Settings
My settings -
My settings are serialmike settings plus a few changes -
R-Gain: -1
G-Gain: 0
B-Gain: 0
R-Bias: -1
G-Bias: -3
B-Bias: 7
Are you saying thats what you got with my custom mode calibrated settings plugged in your set?
Doesnt make sense. The difference in the settings would require you to take red up in order to make up the difference in the red and not by a little bit. Pretty much by 3 bias and gain or more. Due to the other colors being closer.
Something there doesnt add up.
Also for info sake. What size set are you running?
glgl
Thanks, but I just realised I'm an idiot
I'm requesting dimensions for the 32EX500 box! I didn't specify that in my last post.
So...32EX500 box dimensions, anyone?
just go to any electronics store with a tape measure
they have 32 inchers all over the floor
I have the 55". I used your settings and tweaked from there. It makes sense because you have red at -8 and I brought it up to -1 so that is a +7 difference am I not correct?
Oh yeah yeah, I see it. I looked at it before coffee. some how saw that reversed. Yeah makes perfect sense in my mind. Interesting. Looks proof positive that the sets are different. Odd in the way that they are. Looks also like its proof that the ex5 line has blue low for all the sets as I suspected. Because people were complaining of to reddish or orange. Also interesting that lowering red wasnt needed on yours.
Looks good though.
As a side I just no more than 5 min ago went back and looked at mine real quick since its been many months. Still the same cant get more perfect than the settings posted for my 60ex5.
Quick question about the KDL55EX500 (Sony BRAVIA 55")
One of the reviews on BestBuy.com lists this as a gripe:
· When using an HDMI connection you are not allowed to change the "wide" mode to "normal". Meaning if you are trying to watch something that is in 4:3 aspect ratio it will stretch the image forcing you to use a component connection to achieve "normal" viewing mode. Totally bogus considering older SONY TV's have this functionality.
Can anyone verify if this is actually the case? Thanks.
I run HDMI exclusively and haven't found this to be a problem at all. If the content is 4:3, it displays with bars on the sides. No streching here!
