I am looking at either the 47" or 55". Can you customize each input to their own settings or can you only customize the Picture Mode?
Originally Posted by Unoriginal Name I am looking at either the 47" or 55". Can you customize each input to their own settings or can you only customize the Picture Mode? Thanks! |
Originally Posted by avsforumnewbie /forum/post/19747929
Sharpness set at 50 was the trick to get my Mac Mini dialed in with the TV. 50 seems to be the "0". Anything below is -, anything higher is +.
hey i've been browsing and decided to finally join the forums
I just bought an 42LE5400 from Tigerdirect and have been reading about the IPS panels, just wondering if the panels matter that much, since i just ordered it 2 days ago, is this a new panel on their new TVs or what, just worried because it's being delivered the 4th and wondering what i should expect
Originally Posted by jclayt2 /forum/post/19750043
does it make that big of a difference? (what is the difference too?) or do some VA models just have more problems than the IPS?
Originally Posted by bym051d /forum/post/0
Definitely send everything to your receiver and 1 cable to your TV.
The TV is going to downmix everything to 2-channel when you send out of optical audio.
Originally Posted by dcjes /forum/post/19751908
Also will this mount work with the TV well. Is anyone using a ultra low profile mount for theirs?
Originally Posted by PWH1 /forum/post/19751999
It will work, but what you will need to realize is that the tv will be very tight to the wall. You will need to take into consideration where the connections are in the back of the TV. I have a regular wall mount (not low profile) for my 47" and without 90 degree swiveling HDMI connectors, there would have been no way I could have gotten the HDMI cables into the jacks without them.
I am not sure of your intended setup, but just be aware that you will have little to no room behind the tv once on the wall with a low profile mount.
Originally Posted by dcjes /forum/post/19752019
I want the TV to be as close to the wall as possible, I have some 90 degree adapters on order. So I am aware of this issue. Thanks for the input!
Edit: I also need to have the network hooked up....hmmmm, this might be tougher than I though....any ideas??
Originally Posted by dcjes /forum/post/19751803
Will I still be able to have different settings for movies, games, and tv?
Originally Posted by AlphaWolf /forum/post/18830614
I did an input lag test, this series of monitors is slower than many others:
http://www.avsforum.com/avs-vb/showt...7#post18830597
The short of it is that my 47LE5400 is consistently 99ms slower than traditional analog monitors.
This isn't that far off from a measurement done by somebody else in that thread who reported the 55LE5400 at 82ms.
I'd appreciate however if somebody else could test it as well to confirm my results as I am in the process of deciding whether or not I should get a different TV.
