Mede8er Can't Find External Drive or Files!
Hello, all. Had my Mede8er for a few years and really enjoy it. But allll of a sudden I am having issues with my MED100X3D! I have my files stored on a WD MyBook 3TB. When hooked up to the PC, I can see, add, and play mkv files. When I connect the external HD to the Mede8er, it doesn't even recognize that the drive is there! No movies, artwork, music files, nothing! Not even that a USB drive is present under Media Library. I thought it may just be something with my external had drive, maybe using the Safe Remove feature in Windows 10, buuuut...
I have some movies stored on an internal drive on the Mede8er. The Mede8er picks up on the drive, and shows the folders. But click on one, and the mkv files and jpg artwork are missing. Nothing! Hook up the Mede8er to my computer, and the content is visible and working.
I eve tried to use anther hard drive, a WD MyPassport. I downloaded two movies, then hooked it up to Mede8er. It shows all previous folders I have added (music, video), but the mkv file only shows the folder. Once I click on it, the folders are empty. Again, everything is operational on my pc.
This was before the latest firmware update, and I have since installed it. Same issue.
Am I missing something? Is my Mede8er fried or is every drive I have been corrupted. Please help! I could go through the laborious task of moving, formatting, and reading, but not sure if this is even the problem.
