5361 - 5374 of 5374 Posts
I thought I'd quote myself in this thread rather than start a new thread about our small remote once again suddenly going through batteries on an almost weekly basis. Any other Shield owners noticing that they're small remote is going through batteries faster than usual?
Well, I got another low battery warning last night after new batteries were installed four days ago. Dear Nvidia, what's going on?
Are you up to date?
If you mean the latest Nvidia software and remote and controller software, yes. I checked for software updates for those first thing. Thanks.
Yeah it was a more common issue in the past but I asked because I thought they fixed it. I had it a few times, changed the battery and then realized it was fine so I just
closed the notification and ignored it. I ended up moving to the 2019 Shield so its no longer an issue for me.
Maybe what I've made bold in your post is exactly what Nvidia wanted increasingly frustrated owners to do.
I'm reminded of the recent "engineered" slowdown in response time of Apple phones. Owners got a bit frustrated with it and upgraded to a new phone. But I'm going to hang in there and see what kind of response I get from Nvidia, if any. Our controller still works great, so using that all the time may ultimately be my only option.
The interesting thing is that this low-battery thing appeared out of nowhere, just a couple of weeks ago. The batteries that were in the remote a that time had been in there for literally several months. Then, bang, the low battery warnings start appearing.
FWIW, I tested the voltages on the last set of batteries I removed from the remote a few days ago, as well as the ones that are in the remote today, plus several brand new batteries still in the pack, and I found just below 3.2V on all of them -- in other words, normal battery voltages for a CR2032 rated at 3V. So this is not a low-voltage issue. It's yet another FALSE low-battery warning issue that is caused by some screwed up communication between the remote and the base station.
I know its not the solution you're looking for, but what about getting a universal remote control? You wont have to deal with the low battery problems anymore. Logitech make some inexpensive ones, you have just one remote that controls all (8 or more) your entertainment devices. You can use it to control the shield with a USB IR
Just a suggestion.
Just a suggestion.
Thanks, but if tthe small remote does not work out, I'll just use the controller -- to which the Shield responds instantaneously. If I were going to buy anything, I'd buy a brand new Nvidia small remote.
As a Harmony hub user, your response is amusing. Haha.
Last night the small remote suddenly became un-paired with the Shield box, so we used the controller for the rest of the evening. This morning, July 10, 2020, I changed the small remote batteries, woke up the Shield box using the controller and, again, the small remote was not detected. I chose "pair an accessory" and, after pressing and holding the center button on the remote for around 15 seconds, the small remote did pair with the Shield box. Right now, 09:28, July 10, 2020, 10 minutes after pairing, the batteries show "full". The stop watch "start" button has been pushed. How long before the low-battery warning pops up?
I hit the "stop" button on the stop watch last night at around 10 PM. Therefore, the "critically low battery" warning appeared approximately 84 hours after the new set of batteries were installed.
I removed the battery tray; waited about 30 seconnds and slid the tray back into the unit with the same batteries. About 5 minutes later I checked the remote's battery condition and it was reported to be "full". Amazing, don't you think? This morning at 08:27 AM the batteries condtion is reported to be "good".
Houston, "we" have the exact same problem that our Shield once had for many months, ending in April, 2019 when Nvidia sent me a replacement remote. I'll report how Nvidia responds to this re-run of the same issue.
Will the "new" 2019 Shield TV remote -- the one with the volume, forward, backward, play/pause buttons -- control the 2017 Shield TV console?
anyone know a way to fix "match content"?
My AppleTV4K works amazing and switches from HDR to Dolby Vision? but the Nvidia Shield never does it trying to figure out a way to make it work. I have Match Content on but it says BETA
What’s your default resolution? Mine says 4K 59.940 HDR Ready and with Match content color space switched on I get HDR or DV just like my ATV4K. Dolby Vision needs to be switched on too.
