41 - 60 of 14533 Posts
I set mine up and used it to watch the Director's Cut of Watchmen last night plus exercised some of the network features and installed the remote control app on my Android. This morning I did a bit of headphone listening.
I'd say that if you have an 83 like I did that it's time to upgrade. Going from the 83 to the 105 is a major step up in many ways. Over-all it's like going from Kansas to Oz.
As far as the analog section I listened a bit with my Senn 650's. These are the hardest to drive phones I own. I have similar feelings about the head amp as the others here. With these high impedance phones the drive available seemed marginal to me. The resolution though was really good. Hopefully that resolution will also appear at the XLRs.
I'd love to hear how it compares to the 83SE.
Originally Posted by JazzGuyy  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22597905
Objectively if possible. If someone can clearly pick it out, when compared.
Originally Posted by Brian-HD  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22597930
My guess is they will sound different because the DACs are stacked in the 83se...I am also looking foward to comparasons.
Originally Posted by ehlarson  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22597900
I'd say that if you have an 83 like I did that it's time to upgrade. Going from the 83 to the 105 is like going from Kansas to Oz.
Nice to know! Now to figure out how to get to my video media easier as Apple's SMB does not work well. Off to see if I can find the profile for Plex.
Originally Posted by himey  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598037
Not to mention that the 83SE utilizes the 9016 dac instead of the 9018. When I went from the 83SE to the 95 I noticed a definite improvement in sound quality. It wasn't substantial but it was noticable.
I received my 105 on Thursday, and have had it running since. I bought it as an audio source only. I have not had a CD player in my system for a year or two, using only streaming, Mac mini, or turntable as a source. I wanted a CD player again as it is convenient to play CD's from the library, instead of loading them into my mac.
My thoughts so far, the 105 is big, bold, and dynamic. Images are pretty well formed, detail is good, but most importantly, it is fun to listen to. Straight out of the box, I listened to two CD's beginning to end. That is a very good sign. I don't normally do that.
It is far too early to have any real conclusions about this, but I am pretty impressed. I used it as a streaming dac from my Squeezebox Touch, and dac from my Mac, and it does pretty well in these areas also. Again, to early to really tell if it is a real giant killer in that role, but it is at the least quite good, even at this early stage (and I am comparing it to some pricy dacs).
This is my first Oppo product, so I can't compare it to any other models. I just post this in case potential purchasers are on the fence waiting for feedback on the 105. I don't think anyone would be disappointed in its performance. I am sure it will only get better. I do know break-in makes these things better... I would also say that the Pure Audio mode really does provide improvements. It gets noticeably cleaner.
It is quite a deal at $1200.
Originally Posted by Torqdog  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598059
When compared 83se and 95, I was unable to get your result. i really tried to discern if there was an improvement.
Originally Posted by Roger Mathus  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22597735
I have a 93, 103, 95 and now a 105. I have had no problems with VuDu. On the signal speed test utility, what readings do you get? I don't think that the player is the source of your problems. Can you move the OPPO closer to your wireless router and get a VuDu connect to run the test? If not, I think there is a utility on the Samsung????
How does the analouge output between the 103 and the 105 compare? I am finding my outboard DAC to sound better than the 103 and was hoping somoene could compare the two. The bass in the 103 is a tad on the soft side compared to my outbard DAC. I was thinking of picking up the 105 and doing a side by side, then retrun the 103 if I find it worth the extra $700+ dollars. Can you providse any of your findings?
Originally Posted by JonStatt  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22597797
Ha! So I didn't imagine it. That is exactly what I described above as the difference I heard with the 105 over the 95....more detailed in the upper register.
Do you guys use the 95's FL/FR option in the audio setup? if so set it to downmix and there will be more detail and tighter bass, If you guys would check this out that would be great:)
Originally Posted by Brian-HD  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598096
As I said, the differences weren't substantial but noticable. IIRC(it's been so long) bass was a tad deeper with the 95 and it just seemed there was a slight bit more definition in the highs. I did however notice a better multichannel performance (SACDs) with the 95 over the 83SE as there was a definite step up in performance that was realized when going from the 9006 multichannel DAC in the 83SE to the 9018 multi used in the 95. That made all the difference for me as I do listen to allot of SACDs and concert blurays via analog.
In regards to the headphone amp:
Originally Posted by JonStatt  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22597119
The end result is a very smooth, easy to listen to, well balanced sound. For those looking for more excitement, it may fall short and for those looking to chill-out and relax, it is going to be very pleasing indeed. It isn't over-powering at any frequency point and is fairly neutral. If it just had a bit more oomph it would have been perfect.
Exactly. More juice to the headphone amp would have made my higher-end and harder-to-drive cans "sing" and the Oppo would be that much better. As it stands now, the 105 and my LCD-2s are very listenable, but the LCD-2s (when driven by the 105) just don't excite me as much as I know that they are capable of doing. Perhaps this will change as I do more extensive listening.
Here's a quote from David from the anticipation thread:
Oppo is very conservative in their current design spec for the headphone circuit. Look at the table below for the rated 0.001% THD spec. The chip is capable of much more output power at this low THD than what Oppo has designed it for.
Impedance Oppo Spec Chip Spec (@0.001% THD)
600 ohm 12mW 80mW - 150mW (depending on whether Oppo uses +/-12 or +/-15V supply rails. Higher voltage produces higher output powers).
60 ohm 91mW 850mW - 1300mW (depending on whether Oppo uses +/-12 or +/-15V supply rails).
32 ohm 137mW 1500mW - 2000mW (depending on whether Oppo uses +/-12 or +/-15V supply rails).
I hope Oppo gives the user in software for the option to set the maximum output power level of the headphone amplifier. This will prevent alot of users from complaining about the 'lack' of punch or whatever for those more exotic headphones that require higher current drives(not the iphone typessmile.gif!).
- David
If Oppo could provide this option in a firmware upgrade I think it would make a lot of us very happy.
(And to heck with those users who use cheap ear-buds with a $1200 player...all TWO of them.)
Today, I plugged in my Denon AH-D5000 headphones and used them with the 105. These cans are much easier to drive and results were, as expected, very good. Plenty of volume and room to go higher. (I listened to the DVD-A of Rough Mix and a CD by Loudon Wainwright III.) The Denon 5000s, unfortunately, aren't in the same league as the Senn 800s or the Audez'es.
Originally Posted by tomcrown1  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22597521
Is it just me? The bass in the 105 sounds a lot more tighter then the 95. It has a more real world sound to it. The bass in the 95 always sounded like a big boom box..
I agree. The bass on the 105 is very nice--tight and well-defined.
My last Oppo was an 83 (modded to be region free) so the 105 is a significant upgrade for me. Tonight I'll focus more on the video aspects of the unit.
Originally Posted by Franchot  /t/1439524/official-oppo-bdp-105-owners-thread#post_22597027
Sorry about the lack of description. I only had a short amount of time to set the player up and test out how the headphone amp sounded. By "nice" I mean the sound was smooth, detailed, and non-fatiguing. (I was listening to selected cuts from the CD versions of the Cure's Greatest Hits and John Hiatt's "Riding With The King" and an SACD of Bowie's Ziggy Stardust.)
I did some further headphone listening tonight switching back and forth between the headphone jacks on the 105 and my Yamaha 2000 and my Sennheiser 800s and the LCD-2s
I put in Clash of the Titans 3-D in the 105 with the 800s and the 105 didn't seem to muscle up a great deal of volume. The detail was very nice, but I had the volume up to 90 and above. On the Yamaha, there was plenty of headroom to go higher and the movie played much louder. Switching over to the LCD-2s, the 105 provided a better sound (clearer and more detailed), but again the volume was up to 85 to 90 to give me the sort of immersion that I craved. Again, the Yamaha easily played the movie louder if not as cleanly and crisply.
I put in Quadrophenia SACD (import) and again I was rather disappointed with the amount of volume from the 105 with the 800s. I could push the volume to 100 without distorting, but I've never listened to my cans at near maximum volume before. (Maybe it's a psychological thing or maybe I'm just getting old.
.) Quadrophenia sounded better on the 105 with the LCD-2s, but the volume was in the 85 and up region.
At this juncture, I'm enjoying how the 105 and the LCD-2s interact with each other. The 800s and the Yamaha seem to work better for me. I'll let my ears (and body) get a good night's rest and do some more exploring tomorrow.
Franchot:
Thanx so much for taking the time to review the headphone amp of the 105. It seems my fears about the power of the headphone amp have been realized and they can't increase the power w/o changing a capacitor somewhere on the 2Ch board. I can imagine modders charging $100 to change a cap
- David
Originally Posted by Hikmer  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598116
I have not compared the 103 to the 105 for analog out. The 103 is in my dedicated theater room. I use bitstream out over HDMI to the high end $7k DENON processor. The perceived difference in a comparison test would likely depend somewhat on the other components in the system. With a very transparent system, I suspect that the 105 would easily out perform the 103. In other words, different people with different systems would see varying results. In my audio system I use the 105 for its analog out performance. In my theater room, I use the 103 for its video performance and other OPPO player shared features.
Originally Posted by audiofan1  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598275
I also find the downmix setting more to my liking. It seems to provide a more full bodied presentation but I have not sampled a lot of different discs yet. The fine detail in the new Naxos disc with Copland's piano concerto is amazing. This afternoon I plan to test some coral music to see how it handles the complexity. Then I will go to solo voice.
I have a Mc Labs MC 8207 amp and a MX 121 processor. My blu ray player is a Panasonic DMP BD80-a few years old. I am thinking of getting the Oppo 105. Will it make a real difference with audio and video.
Thanks in advance,
Bruce
Originally Posted by Torqdog  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598347
As I said, the differences weren't substantial but noticable. IIRC(it's been so long) bass was a tad deeper with the 95 and it just seemed there was a slight bit more definition in the highs. I did however notice a better multichannel performance (SACDs) with the 95 over the 83SE as there was a difinite step up in performance that was realized when going from the 9006 multichannel DAC in the 83SE to the 9018 multi used in the 95. That made all the difference for me as I do listen to allot of SACDs and concert blurays via analog.
My post should have stated 2 ch.
Originally Posted by Roger Mathus  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598468
Hmm...I haven't tried this yet, but to make sure I am clear. You are playing "stereo" music and are finding a difference on the dedicated stereo outputs if they are set to downmix vs Front L/R?? If so there is something wrong (firmware) that needs to be fixed. There should be absolutely no difference with that setting for the dedicated stereo output when listening to stereo music. If you have a crossover set and speakers set to small I am guessing that may influence things. In my case though all speakers are set to large, all at default output level and default distance. Therefore there should be absolutely no difference....
BDP-105 arrived today. One of the things I really needed was for it to handle the audio from the TV, however the audio via both ARC and Toslink is severely out-of-sync (was perfect with the old Outlaw 950 that I'm retiring). The sync issue remains with all tested sources from the TV, both OTA and using Vierra Connect for Amazon Prime feeds.
I do hope a firmware fix for this is on the way soon.
Read the FAQ!
Originally Posted by darkphader  /t/1439524/official-oppo-bdp-105-owners-thread/30#post_22598652
What's the direction of the error? Audio ahead of video (audio needs delay) or audio behind video (audio already has too much delay)?
--Bob
