1 - 20 of 7278 Posts
Premium Member
It has been requested to start a separate thread for Calibration, Tweaking, Technical Issues, Etc.
So here we go!
Good luck and Congrats to all you new Plasma Owners.
Happy Plasma-ing!
Dave
Excellent idea! Thanks for being on the ball. Has there been any change in the way input setting are stored for these px60u/600u sets? Are they per input specific or mode specific (vivid, standard, cinema)?
Anyone care to comment on the new H-Fill aspect setting?
Can anyone confirm if the overscan controls have been included in the px60/600? I heard this is crucial in order to obtain 1:1 pixel mapping from a pc via the digtial inputs.
I'm using Warm and Light.
I wonder what temp is closest to 6500K; usually it's the Warm setting. To know for sure we need a professional calibrator or review.
Also wonder if it's better to choose the Light setting and darken Brightness or choose Dark and lighten Brightness. What's the difference?
I have the same question as HomeTheatreMaven re: 6500K. When I tried my initial calibration of our 50PX60U, the display was set at Normal and Light. Below I've copied my settings post from the original Panasonic availability thread. Thanks for setting up this separate Settings/Tweaking thread.
baloo
Originally Posted by baloo /forum/post/0
I took a first shot last night at doing a very basic calibration of our new TH-50PX60U. I've spent some time in the past trying to obtain the best quality picture in our basement front projection system ( our home theater ), so I've used AVIA and other tools several times. However, I am definitely not an expert, so YMMV greatly.
The new 50PX60U is in our upstairs family room. There is some ambient light during the day and the walls are a light yellow. I calibrated in the evening using AVIA and an OPPO OPDV971H DVD player connected to the Panasonic through the HDMI 2 port. (We also have a DTV HD TiVo, although we'll be switching to Verizon FIOS or Cox soon.) During calibration, I kept the room dim (some overhead ceiling lights on a dimmer) but not dark, as this is our typical viewing environment for this room.
Like others have reported, I found the default "Vivid" mode settings out of the box artificial -- they made the picture look blocky and oversaturated. I first switched from Vivid to Standard mode. The default settings in Standard mode were: Picture +20, Brightness 0, Color 0, Tint 0, Sharpness +15. After doing the AVIA video calibration tests, my settings were:
Picture +12
Brightness +5
Color -2
Tint -5
Sharpness -3
I'll check the settings again in a few days with AVIA, as I've found that it sometimes takes me a few times to get the best settings. I'm also not sure I had all the other video options on the Panasonic set correctly (i.e. Light or Dark blacks).
From my amateur viewpoint, the picture is VERY nice -- I'm glad I didn't wait for the 600, which I had earlier debated. It's hard to turn off the TV. My next step is to research and buy a relatively inexpensive surround speaker system to upgrade the sound in the room ...
baloo
Banned
Just an FYI... with Time Warner Cable, an SA PowerKEY CableCARD and a 50PX50U... the Black Level is auto-adjusted to dark for 480i and to light for 720p/1080i. I use the Normal setting with the Warm color adjustment.
I have all settings backed off to -5 for brightness and picture as I let the panel break in. Its like beaking in my engine, this is the worst part, having a toy you can't fully exploit yet
Wouldn't the recommended display settings people suggested for last year's model work just as good on this year's? Or would there be some major differences?
Banned
IMO... the best approach is to begin with Panasonic's default Standard setting then turn the brightness, contrast and sharpness levels down as low as is acceptable to you during the first 100 hours of operation. During the first 100 hours display no black bars and avoid the prolonged use of static images. Until the break-in period is over it's not feasible to calibrate or tweak the panel's picture settings with any degree of accuracy.
Got my 42PX60U yesterday. This set replaces a 27-inch 1992 cathode ray tube Sony XBR which still has a great picture (in SD, of course).
We put the TV at the foot of the bed so we will be watching from about six feet. Only had a couple of hours to watch, so these are preliminary impressions:
Picture quality is great, but default settings are wrong. Vivid is way too fiery, Standard has too much contrast and artificial sharpness, and Cinema is lifeless. In Standard mode, I decided to turn down Picture (why doesn't the TV industry like the word "contrast"? "Contrast" is much more descriptive than "Picture") to about +20, and leave everything else at 0. I will calibrate when my Avia disk arrives.
SD is very good when the signal is good. Unfortunately, the signal varies greatly between channels and the differences in PQ are much more pronounced than on my old Sony XBR. All in all, SD is very watchable.
I was surprised that I could get HD channels over Time Warner Cable without a STB! Local channels and a special KPBS channel with different programming than regular KPBS. I though I needed a cable card to get HD over cable without a STB. Evidently not!
Now what do I do with the Zenith Silver Sensor antenna coming in the mail next week?
Needless to say, picture quality in HD was wonderful. Very sharp and lifelike, fantastic color saturation, excellent contrast, deep blacks (almost as black as my old Sony XBR), and very pure whites. This is from a few minutes of watching the KPBS HD channel, and snippets of the March Madness college basketball games.
I watched the opening scenes from the new DVD of Good Night and Good Luck. I was pleased with the purity of the blacks and the whites. The gray scale, in particular, seems very refined and extended, moving from black to white seamlessly. Shadow detail is exceptional, and highlight detail is the best. (By the way, the Dianne Reeves soundtrack of this DVD is so well recorded that I ordered the CD; the saxophone in particular is very real.)
I also watched some scenes from Natural Born Killers, and the PQ was fabulous. Color is very good, although perhaps a little oversaturated because I have yet to calibrate the set.
I used a cheap Toshiba SD-3950 to play the DVD's. It seems that the Panasonic de-interlaser and scaler are so good that even a $50 DVD player looks good. Why would I need an Oppo?
Banned
Does that Toshiba have HDMI? If the new panny scalers are really good than you might benefit from getting the new OPPO player coming out in april. It will let you feed the panny a 480i signal thru HDMI and this will let you take advantage of the 16 bit processing and better greyscale gradations only available thru HDMI.
Originally Posted by mugwump88 /forum/post/0
We will need info how to get into the service menu. This will be another informative thread!
Same as previous Models.
__________________________________
BruZZi's Panasonic Plasma FAQ BruzziForum.com
Lots of info for all Plasmas in general.
I'm currently setting mine up. I'm trying to find a good color setting, the one baloo is better than the factory setting, but still not 100%. I'll get it right
About HDMI inputs:
Being new to all of this chatter, I was looking at the photo of the back of the 60s and noted that there HDMI 1 and 2 Audio in jacks. I thought if you connected with an HDMI cable, you didn't need separate audio inputs. I apologize if this is a silly question, but what are these inputs for?
Thanks, that is good information. No, the Tosh 3950 does not have HDMI. I was using S-Video, actually. I was wondering what the differences are between the current Oppo and the new one. So the new one will NOT have a de-interlacer and scaler, but it will have HDMI and be a universal player, including all manner of DVD's and CD's, including Super Audio CD and DVD-A?
man what a screen in HD.
Ok, I have a question, I currently don't have HD cable or Sat, which isn't allbad cuz most of the HD watching I do is sports and most of that I can get over the air.
My issue is, when setting the TV up for TV watching, it wants to do a channel scan, it seems to look for either cable or antenna but I can't seem to figure out how to make it remember both.
I'd like to set it up to scan the cable channels, but also be able to connect up my rabit ears for HD when I need it without blowing out the cable settings. Any idea how to do this?
using rabit ears for HD, I find it very ironic, but the quality is incredible.
Banned
With the PX50/500Us one had to re-scan the channels each time when going from cable to antenna... sounds like Panasonic hasn't changed things with the PX60Us either.
Originally Posted by elight50 /forum/post/0
About HDMI inputs:
I believe it's to connect DVI devices which are video only.
DVI+adapter --> HDMI
audio --> "HDMI audio" rca jacks
