Any one experience this or have any pointers?
Sent from my LG-H871 using Tapatalk
Sounds like it changed the gain on the speakers.
The only reason would be if the furniture changes you made caused it to think that the sub was really high and it had to bring everything down to match it.
Ideally you want the sub to be between -12 and -5 in the settings. Up to 0 is fine, you just don't want a positive number. Ideally you want all the speakers to calibrate to -8 to -3. Within that range it just means everything is matched. If the subs are at like -15 you are maxed out and need to turn the gain on the sub down some.
Since in most systems the sub gain is the only "changeable setting" you have outside of the receiver it is the one that is either way off (-15 or +something) or within range of adjustment (-12 to -5).
Just adjust the sub gain to get it to show say -8 or so on calibration and the rest should be within -8 to -3. If not then I would keep turning down the gain on the sub until the rest of the speakers fall into that range. If they never do, maybe something got stuck inside the hole on the microphone, or the mic is defective.
I have two different setups, one on the VSX-LX503 and the other on an Onkyo TX-NR787 (same exact tech inside both receivers, even if the firmware interface is slightly different, the both calibrate the same, using the same mic) and I ahve no problem getting both to calibrate within those ranges and have no issues.
