441 - 445 of 445 Posts
Hi
All I know is that my N-50-K works with the control app. However, the app does not exist for Android. Only for IOS .....
Cheers, Mike
Hi
But the App worked well with the my previous Android 6 and earlier not now with Android 10.
Regards
Enviado do meu SM-A516B através do Tapatalk
Do you have the N-50 or the N50AE?
What is the latest firmware version you are installing?
Kind Regards
Hi
N-50A.
Firmware: s9819. 5016.1010 (I think this is the last one).
Regards
Hi
Unfortunately, on my Samsung A51, Android 10 I couldn't get the above App to work.
I believe that for this Android there is no remote control for the Pioneer N-50a.
Regards
Enviado do meu SM-P610 através do Tapatalk
I have had an N-50 for several years, but it has just developed a problem. When I push the "On" button, the blue light comes on then fades out, then comes on and fades out, over and over. It won't ever power up and the display never lights up. The light just goes on and off (it will do that for HOURS). Has anyone else had this problem, and if so how did you fix it? Any help welcome.
-Tac
