Originally Posted by Colmino /forum/post/0
Three pages and nobody's brought up the specs. Alright.
Let's say Warner (or whoever) finds whatever wasteful solution they can to utilize all 8mbps possible for the audio, and also utilizes all 40mbps possible for video. On a dual-layer disc, they will have to have no less than 140 minutes (two hours, 20 minutes) of video to use up the whole disc. This is a maximized scenario, and assumes that the Blu-ray spec allows for a 40mbps VC-1/AVC stream to be decoded - I frankly don't know if it does. (We'll ignore MPEG2 since it's safe to stop pretending that it was ever a defendable codec for HD media.)
Most movies aren't this long. So unless there's oodles of bonus content waiting to fill the gaps for every movie, people had better get used to Blu-ray discs that aren't fully utilized. If the Blu-ray spec had allowed for better bitrates, there'd be reason to raise an eyebrow over underutilized media.
Yes, I can see quite a few good points here, but I'm not so sure it's the ones you intended. Now let's check this data real quick, the 2:20 running time you are talking about is referring to a full 50gb blu-ray disc. Let's say the average movie is around 1:45 to 2 hours long, that would mean between 20-35 "oodling" minutes of extra material would be needed to cram the last bit of space on a full 50gb blu-ray disc... The comparative running time on a full dual-layer 30gb HD DVD disc would be about 85 minutes. I don't know about you but I can think of a couple of movies longer than that, oh say 90% of them
. Which means, that as long as Warner keeps just using the same encode on both HD DVD and Blu-ray versions, the only movies that can use maxed out bitrate would have to be shorter than one and a half hours long...
Lets check those numbers though, shall we? After all, is 8mbps really just a wasteful use of space for audio? Well, just ONE LPCM 5.1 soundtrack uses 6912Kbps, and there is usually an option for standard DD5.1, another 640kbps+. It's not very unusual with one or more commentary tracks and additional french / spanish audio tracks. Maybe French/Spanish speaking people even want high quality audio too?! It doesn't really seem like 8mbps is that hard to reach after all for audio?
According to wikipedia, the maximum video bitrate for Blu-ray is 40.0Mbps, which yes does seem a bit on the excessive side, but still within the specs. Let's just drop that number to 30Mbps for the video bitrate, and we have a nice, healthy 175 minutes of high bitrate video available on a full 50gb blu-ray disc. Most movies are not longer than 3 hours, and can therefor fit nicely and still use a very high video & audio bitrate, and even have space available for HD extras.
But, aren't there still going to be movies that are too long to use a bitrate that high and still fit on one disc? Yes, there are. Let's check a few candidates for this category...
Gladiator (extended) 171 min - Wow, just under the limit...
Titanic 194 min - Yep, well over
LOTR: FOTR (extended) 208 min - Yeah, what do you think - it's LOTR
LOTR: TT (extended) 223 min - Same, of course...
LOTR: ROTK (extended) 251 min - Ditto
Godfather 175 min - Just passed with a whisper
Godfather II 200 min - Again, over
Godfather III 169 min - Another one right on the line
I could continue, but I'm sure you get the drift. Then again, how many would really want high bitrates on these kinds of movies anyway, right?! Oh, you would? My bad...
So what about HD DVD then? with the same 30Mbps video bitrate, that would come to 105 minutes, just for the movie, to fill up a dual-layer 30gb HD DVD disc. But, there really aren't that many movies longer than 1:45, huh? But, what kind of bitrate does that mean you have to use on a movie like LOTR: ROTK??? Uh, about 15Mbps... Exlcuding menus, additional audio, commentaries and extras of course. What, you want more than a 640kbps sound track? You ungrateful XxXx... Well then it would come to around ~10Mbps for the video... What do you mean that's low?? How much bitrate does a movie like LOTR:ROTK really need anyway? Hardly any action going on, no hard to encode stuff like fire, fog, rain etc either, so what are you complaining about!!
So, long story short - Why would they really need to do a separate encode for blu-ray anyway, bah.. it's all HUMBUG!
