1 - 20 of 328 Posts
Well, I finally did it and purchased an HDTV (my first) on this dark and dreary Black Friday. I have a 90-day no-hassle return policy starting...NOW! So here goes...
Technical specs
From: http://www.polaroid.com/global/detai...bmLocale=en_US
Marketing Jargon:
  • TLX-04240B: 42" Full High Definition Widescreen LCD TV
  • Full HD 1080p with 1920 x 1080 resolution for a crystal clear, true-to-life picture
  • Dual HDMI inputs provide increased HD connectivity
  • Widescreen picture and 178 x 178 Viewing Angle ensure that everyone in the room will have the best seat in the house
Features:
  • 1080p/1080i/720p/480i/480p digital compatibility
  • Cable-ready high definition ATSC tuner
  • Progressive scan
  • 3D comb filter and de-interlace scanning
  • True-to-life color and picture quality
  • Dual HDMI connectivity
  • Built-in stereo speakers (15 watts x 2) with simulated surround sound
  • Pre-programmed sound controls (Bass, treble, balance)
  • Trilingual on-screen display (English, Spanish, French)
  • Closed captioning and sleep timer
  • Includes full-function universal remote control and a Quick Start Guide for easy setup
  • Detachable TV stand for easy wall-mounting
  • VESA 200 x 400 standard mount system compatible (not included)
Inputs & Outputs:
  • 2 HDMI inputs
  • S-Video input
  • 2 component video inputs
  • 2 composite video inputs
  • Coaxial RF input
  • 7 audio inputs
  • VGA (D-sub) input
  • Audio output
  • Headphone jack
  • Coaxial digital audio output
Specifications:
  • Resolution: 1920 x 1080
  • Brightness: 500 cd/m2
  • Contrast ratio: 1200:1
  • Response time: 8 ms
  • Viewing angle: 178 x 178
  • 16:9 widescreen picture
Absolutely nothing relevant turns up Googling this model number (aside from two Craig's List listings from people who took advantage of the same deal I did and are now trying to sell them for a higher price...) and Polaroid lists this model as "New" so I don't know what's going on here. Heck, Google didn't even return the Polaroid site above as a hit!
Anyways, more to follow on this strange set as I unpack and test it out!
For what its worth, I have had this set for about a month now.
I know it allows 1080p feeds via both HDMI and component.
Also, it has a QAM tuner built in for those wishing to use it for digital cable feeds that are unscrambled.
I calibrated the set and am very happy with the picture so far.
I know many people will turn up their noses toward this set because it is a budget model from a non name brand CE. However, in my mind at least it is a little gem of a set.
Discussion Starter · #3 ·
Jeff, yes i've heard similiar things from other people as well, claiming it's a decent set. That's my hope. I know i'm not supposed to discuss prices, but let's just say this was significantly cheaper than any 1080p set I could find this Black Friday, and frankly, was surprised the particular store I bought it at still had 9 in stock, out in full display in front of the store, 4 hours after they opened their doors!
I looked at this today and it seemed like a pretty good deal IF, and this is really important for me, the remote control allows you to turn off and on the captioning directly ...that is, not having to go through a menu to do so. can you tell me if the remote control has a CC (closed captioning) button?
There are about 15 of these remaining at our local conglomerate otherwise known as Wally-World and even though the sale price was good from 5a - 11a according to their BF ad, the store managers said the price will be good through the end of Saturday.
Should I pull the trigger here? It appears to be a good deal when compared against other 42" 1080p LCD sets, and I don't need a high end set - this would be going in our master bedroom for mostly late-night viewing. Therefore nothing with a high-contrast is needed, etc. and I don't want plasma due to the high burn in risk with us using mostly 4:3 mode with TiVo.
1080p-less in Dallas,
skittlebrau
I bought this LCD today too. So far it seems pretty good. I had to tweak with the color settings, still not too sure I'm in love with the color. The picture seems nice and clear using the local HD broadcasting.
I put a standard DVD in from my DVD player (non-HD) and it wasn't impressive.
Has anybody had a chance to compare this TV to another one side-by-side in HD mode?
Has anyone figured out how to program the remote to control other devices such as DVD players? The instruction manual says to enter a "five-digit code" for my device, but all the manufacturers' codes in the tables are four digits, and they do not seem to work with the remote. The phone support people at Polaroid told me just to add a zero before each code, but this did not work for me either. Looks like I might just have to go though the more time-consuming "code search" process for each of my devices...
To the person asking about closed captions, yes, the remote has a "CAPTION" button that directly turns captions on and off, without going through a menu. However, you might need to press the button as many as 10 times to scroll through all the different caption settings (CC1-4, TEXT1-4, and Service1).
Take a look at the polaroid website (sorry I'm not allowed to post the link to the helpful remote_ug.pdf file since I'm new). Basically all the codes are missing a leading number. 0 for cable and satellite, 2 for DVDs and VCRs
Good luck
Thank you. I found the PDF help file, and using a leading 2 instead of a 0 for my DVD player solved the problem. Funny that the telephone technical support people at Polaroid weren't able to tell me that!
I own this, as well. So far, I prefer my Magnavox. The picture isn't as clear.
How does one tune with the QAM tuner?
The blacks are okay, but I've seen better.
Seriously thinking of returning it.
so has anybody actually watched anything in high def on it? HD DVD or BluRay? This will be the first High Def TV i've owned. Can you get 1080p for 800 anywhere else?
I have and like this. Am watching a movie right now on it. Looks better during the night time. I have no idea how to use any of the features (HD, etc). Anybody want to help me out with some simple tips? Thanks!
Discussion Starter · #18 ·
Hey guys, nice to see some folks that bought this as well today. I've been watching some HD channels on this set over the past 5 hours using QAM. Scanning for the digital channels was extremely easy: under the "Cable/Air TV input" I just went into the menu, selected the TV icon, then clicked scan for channels. After about 15 minutes, all my analog and digital cable channels popped up and I was watching HD in no time.
As for the HD quality, well that's where I have to say i'm a bit disappointed. I don't neccesarily think the picture is bad, but the built-in MPEG2 decoder seems to definately have some issues, in my opinion. There are a lot of artififacts on the screen, even during non-motion scenes. The set didn't properly deinterlace the CBS HD signal, so at times during fast motion I could see interlacing artifacts as well. It definatly looks like it has something to do with the decoder, and i'm quite sure it's not my cable feed because testing the same signal out using MythTV in Linux, my HDTV capture card displays the channels a heck of a lot clearer. I still get macroblocking in scenes with high motion, but I KNOW that's because of over compression from Comcast, and not due to faulty lines.
The positive thing though is the OSD graphics looks very clear; a lot clearer than the HDTV channels I got. That leads me to believe there may yet be some hope for 1080p resolutions. It wasn't mentioned above, but this set comes with a VGA-input as well. Seeing as I don't have a DVI->HDMI adapter to try, i'll test the VGA input tonight and report back my findings.
I just bought this set today as well. How can you pass it up for $798? As long as it's not your main home theater set you'll be good to go and happy with it. This is for my bedroom. I have a 42" Sammy plasma I was going to use but I don't want to fall asleep and burn in a DVD menu.
Plasma's are a huge pain in the ass and definitely not worth the trouble. I'd take the ease of use and risk free operation on this cheapo Wally-World bought Polaroid LCD over my expensive Samsung Plasma ANY DAY.
No more burn in worries. Bring on the Madden '08. Set looks great, picture is acceptable. No qualms or gripes from my corner.
Enjoy your new TV guys
1 - 20 of 328 Posts
