I have been very happy with the L12 and plan to add another sub for dual or upgrade to one that provides more extension/output on the lowest octaves.What’s wrong with the grill? All white subwoofers come with white grill. We can also switch the grill to black if you prefer that.
Nothing wrong with the white grill...I am glad to see more options in white (L12, F12, E15), which would be less visible in larger size, but prefer matte white
So it looks like the best white option is the E15HP and I'm just doing my due diligence to make sure what I order would work in plan A, B, C etc.:
- If I find the gloss white too reflective, it would be easy to wrap the sides matte.
- If I find it challenging to calibrate two subs...no problem, I can use the E15 alone, since it would fit in the current L12 location.
- If it doens't work in current L12 location, it can fit in a couple other spots until I gain the tools/knowledge to calibrate both. Unfortunately, my room is uneven (concrete slab, multiple corners creating boundaries in an open floor plan). From what I understand, REW works best with even parallel walls.
