16121 - 16140 of 52774 Posts
You'd hate how I did it, test equipment and all that science junk, but as long as we both enjoy the music at the end it's all good!
I have several issues with the subwoofer crawl thingie but this ain't the place...
I'm surprised there doesn't seem to be a sticky thread on how to set up a sub, am I overlooking this? I'm looking for a good overview of what to do when my new Rythmik FV15HP arrives, e.g. tips for doing an effective sub crawl, best music to choose for that purpose, tips on optimal sub settings, etc.
Here's a document (.doc and .pdf versions) that I did for a friend a few years back when he bought a Rythmik. It's an aggregation of info from numerous sources so I don't take any credit (or responsibility :D ) for the information...none of it is etched in stone, so use or disregard any of the info, as you see fit. The document has evolved a lot since I originally did it and is decidedly Audyssey-centric but should be applicable to other REQ systems, if nothing else, it has a bunch of links to helpful references.
YMMV.
HTH
My two subwoofers (F12SE) are nearfield, one on each side of my couch but even with Audyssey XT32 + SubEQ HT I get cancellation at the crossover point (80Hz). The solution for me is to set the delay for the subwoofer on the left at 11 o'clock and leave untouched whatever my Marantz SR7008 set for distance. The delay for the subwoofer on the right is set at 0 (7 o'clock). My point here is even with SubEQ HT you may need to trick some parameters in one of the subwoofers. Also I strongly recommend to trust more in your ears than in REW or any other measurement tool.
Well I hope I don't run into this issue after just dropping a grand expecting it to pay big dividends on my system. :eek:
^^^Maybe this will be less of an issue for me or non existant since both of my subs will be on opposite corners of my living room. I'll find out soon enough.
Here's a document that I did for a friend a few years back when he bought a Rythmik. It's an aggregation of info from numerous sources so I don't take any credit (or responsibility) for the information...none of it is etched in stone, so use or disregard any of the info, as you see fit. The document has evolved a lot since I originally did it and is decidedly Audyssey-centric, but if nothing else, it has a bunch of links to helpful references.
YMMV.
HTH
Great, this looks really helpful!
  • Like
Reactions: thtdadav
I think the point is that worst case it's correctable with phase adjustments on the subs, plus XT32 should help a lot. You're definitely moving in the right direction. I updated my receiver from a Denon 1909 to the 4311ci and love it. Not one regret.
Premium Member
IIRC, using Rythmik LFE in defeats its phase adjustment. Only line in enables that. One can adjust sub distances from the avr which is similar to adjusting the sub phase knob.
That's correct, LFE IN bypass crossover and delay functions but I don't use LFE IN, I use LINE IN and set the low pass filter on AVR/12.
75" Samsung Q80R QLED, 2x Amazon Echoes, Echo "Sub", Amazon 4K Firestick. Yep, I'm high end baby.
Enrico, how clean, as far as THD %, do you think a pair of F12's would play a 16 Hz tone at 90 dB in room? If this is ones goal for a dual sealed sub setup, what would your recommendation be? Looking for seamless integration with main speakers i.e. unable to detect that separate subs are playing on classical music.
Premium Member
Let me check and I'll get back to you as soon I'm done with the test. But like I said before I'm the kind of guy that trust more in his ears than in measurements tools. :D
Premium Member
OK. I did the test and I got 90dB with the volume set on the AVR at -23dB. My system is calibrated at 75dB but I run my subwoofers +6dB hot. Of course at 16Hz my windows were shaking but it was very clean. My room is about 2700 cf and very well treated acoustically.
Premium Member
If your room is around 2800 cf, two F12s should be more than enough to archive your goal. I guess you listen to a lot of organ music, right? Also the integration with my main speakers is so perfect that even having one of my subwoofers next to me (3 ft) I can't detect from where the bass is coming.
Guys,
Count me in as a happy owner of a Rythmik sub. Just took delivery of an F12G.
Would like to ask/know how many out there are F12G owners? Set-up was wrong and will have to re-run Audyssey based on laulau's excellent write-up on initial settings at the amp. :)
Thanks laulau:D
Your ears are great because they interpret what YOU like, or "preference". However, they are abysmal in trying to determine if you're reproducing the response accurately, or to "reference" (flat response).
Depends what your goals are...
Premium Member
My goal is to enjoy music, plain and simple. And because is thru my ears that music gets into my brain then I trust in my ears. As a FOH sound engineer for 25 years I learned that you need to trust in you ears more than anything. When you are in front of your desk mixing live you don't have time to take measurements, the only tool you have is your ears. Also flat response is boring :D
YMMV.
HTH
Hi laulau,
Thanks for this, it's greatly appreciated. It should be included as a sticky.
Would like some clarification under item 2. Recommended initial setup when using an AVR. Your write-up mentions that for sealed subs the extension should be set to mid damping before running the room EQ.
In the handout from Brian, he recommends low damping.
I can only assume that Brian's rec is more correct as one can go up through mid to high damping after room EQ.
I've got Focal 716V 2.5-way towers, matching center, and older JMLab Tantal 507 bookshelf rears, powered by a Denon X2000. I have a Rythmik FV15HP sub on the way. Any advice on where to set the crossover point between the speakers and sub?
I figured I'd start with the textbook 80hz "small" speaker setting, but obviously my speakers (even the rears) can go a lot lower than that. To be clear, this is for home theater. For music (I listen to a lot of classical, especially solo and chamber) I'm guessing I'll prefer to let the towers do their stereo thing via the "pure direct" mode and turn off the sub.
Of course there'll be some classical music (organ, and even orchestral) where I'll want the sub to supplement the towers, in a perfect world I'd have two crossover settings, maybe an 80hz one for home theater and a 40hz one for music where I want the sub, but I don't think the Denon will allow me to store two different crossover settings (by all means correct me if I'm mistaken).
Hi laulau,
You're right, there is a disparity between what is in paragraph 4 of the PEQ Installation Guide and what was posted in post #6240. However, in post #8127 Brian provided further reasoning for using Mid damping, so I've always gone with the Mid damping setting. A person could always just try both approaches and see which one works better for them. Experimenting can be fun.
Aloha.
Boring to you, but accurate to the industry. :cool:
Mixers most definitely have to use their ears to record...and I know they do an excellent job. But that's the reason I want a flat response and use measuring gear to achieve it! I want to experience what the mixer wanted me to hear accurately (reference), not my personal flavor of it (preference).
Having said that, for movies I run my bass hot, but it is still a flat bass response, just elevated.
Not trying to start a debate here of what sounds better, reference or preference. Just pointing out different approaches...depends on your goals as I said before.
So I decided that before I buy the Denon X4000 online I would pick it up at my local Best Buy to test it out. I sure am glad I took this approach. Hooked everything up yesterday moved one subwoofer to the back left corner of the room next to the MLP and the other stayed in the front right corner of the room. Ran through the complete calibration via Audyssey and was highly disappointed with the results afterwards. My speakers sounded the same and the subs sounded worse. I got no hard hitting bass next to the MLP like I was expecting. I guess this is a good thing because now I can scratch the need for a new receiver off my list. I'm not saying that the Denon X4000 is bad receiver. It simply did not do wonders for my system.
