What Picture Mode are you using when viewing SDR and HDR content?
For HDR, Game mode...I think exclusively. I've now used it with a PS4 pro, and just the past 2 days on an AppleTV 4k (attached it to an HDMI port that was already setting game mode for a steam link)
For SDR both game mode on those platforms, and I think "normal mode" whatever it's called, for my TiVo Bolt (for both over-the-air content, and streaming I've used it for).
Sounds like you just want to justify your own settings.
It's 20 or nothing for HDR. The TV automatically knows what to do when set to 20 in HDR in terms of tone mapping and etc. Anything under 20 will not dynamically adjust to HDR and will just act as a static setting.
I just want to know what the heck is going on, and how the heck I'm supposed to set stuff. if setting it below 20 disables the mode, then I want to know that, but do you know for sure? I mean I haven't read that anywhere else, and setting is incredibly confusing if that's the case, I mean that would mean "20" should just be automatic, it would mean that shouldn't be a setting at all if that's what needs to be selected and even 19 disables it.
It would at least make more sense to me if 20 were preferred, but that setting just that's the maximum brightness, and any number you said it to is still otherwise giving you the correct effect, just not as extreme brightness differences. But you're saying it actually disables it?
Apple + can only be installed on a 2018 or later tizen model. Did Disney + ever get their app to run 4k HRD on the KS series? (My tv is now offline and I use a roku for streaming).
supposedly it does...it's 7.7GB/hour max which seems to mean "4K" at least with Disney+ (even though the hardware should easily support it, the PlayStation 4 Pro does NOT support HDR nor I think 4K with Disney+, and Max is out at 4GB/hour).
I just got an Apple TV 4K, and the sole HDR content of tried so far is the first episode of the Mandalorian season 2, and it looked better, the HDR effect looked better than I saw last year running S1 on my TV... Though it's possible S2 is just being done better (doesn't seem surprising to me) or I'm misremembering from last year. It seems to switch to HDR though as I recall.
Why are you guys still using the built in apps for streaming?
Do you not find it too slow?
The Fire TV Cube 2nd Gen is amazingly fast. A few months ago I purchased the new Chromecast with Google TV and it isn’t bad either. Not as fast as the Fire TV but still faster than the built in apps.
the speed seems fine, my issues are more that it's missing tons of programs I want to use.
Nvidia Shield is terrible on the KS. It over processes the video and make everything look extra crunchy!
after seeing tons of people recommended, I did a ton of research before buying a device, and it sounds like actually The Shield does a pretty bad job at color accuracy and what not. It sounds like basically the people who recommend it are really just doing so because they have one specific need, and it's really not that great for General usage. I've also seen multiple reports that the Chromecast with Google TV does not do HDR10 correctly at all...it may be that that's only the case in certain programs, as one person is explicitly talking about Disney+, and said if I'm recalling correctly that support for either Google or Disney acknowledged that. reports like that or the main reason I went with an Apple TV instead of a Chromecast with Google TV, because right now my only "need" for 4K + HDR10 on a streaming device is Disney+.
Hopefully in the future I'll be using other things as well, but for now that's my only usage for it, and I'm paying for Disney+, so I sure as heck want it to look as good as it can! I'm not a fan with everything with the Apple TV (both Disney+ and peacock are a little bit buggy and various ways... though they seem a bit buggy in different ways on every single platform I've tried them on). if nothing else though based on my single show I watched on it in 4k + hdr10, Apple TV 4K does seem to do a good job with it.
