Seiki SE39UY04 won't power up - transient red blink
Cheers friends!
I purchased a used Seiki SE39UY04 that 'worked' for about a week. One day I powered it up and noted that the LED bar below the Seiki logo only gave an occasional red blip about every 1.5 seconds. This is the LED that is red when the unit is off and then turns blue when the TV is 'on' or powering up. There is also a subtle click on the TV speakers in sync with the blip.
I've tried various combos of power button press while power on thinking there may be a factory restore or reboot sequence but to no avail . . . but I really don't know the sequence or if there even is one.
These things are usually power supply. I opened the back of the TV face down and observed the various circuit boards. I moved a few cables about then I powered it up. To my surprise, it powered up! So what else could I do but reassemble. After reassembly, the TV does the same red blip and does not power up.
BTW, the PS showed no obvious component failure, bulging caps or transformers or other component issues.
Still thinking it's the PS, I ordered one on ebay. I easily swapped the PS board, its AC input and the 3 connectors. I then powered it up and it came on, once again, display side down on the carpet. Thinking the problem solved, I reassembled.
However, once in the normal viewing orientation, it went into the same failure mode.
So I'm assuming I do not have two bad power supplies. I also note that simply placing the TV in the face down position does not make it work. It seems to like the back panel off but that may just be a fluke as I have only twice disassembled.
For all the trouble I would have been better off just buying another, new unit or a different TV. Did not have my heart set on Seiki, just wanted a TV, 39 or 40" or so that was 4K, HDMI in and had an audio (aux) port. I will be using for simple HDMI input. I also using the Chromecast device, which, btw, plugging it in or out does not change the malfunction.
Ha! It won't let me post a link to my YouTube of the problem. So you will have to search for it. Go to YouTube and search for this string:
Seiki SE39UY04 - blinking red light - not working
If I wanted that TV again, I can find it for $249 Amazon. Bad luck. I generally don't mind buying used electronics.
1) Any trouble shooting ideas that aren't too much work? I hate to go on replacing boards and spending more money. I paid $200 for the TV (before I found it for $249). Is there a reset sequence that might help? I have read on this forum that folks are upgrading firmware. Would that help, assuming it is possible in its current state. Any other recommendations.
2) If I choose to start over with a new 4K 39" TV, what recommendations do you have?
Thank you for reading.
