2121 - 2140 of 2204 Posts
Were you having a similar issue, or something completely different?
Similar. Not being able to keep multiple sonos in sync even with one wired directly to the Orbi main unit. Plugging in a sonos and having the whole network crash (devices disappearing that weren't even sonos).
The building is all brick and wifi is challenging at best.
Hope Sonos is able to solve your problem, I know a lot of people including myself and friends that are not happy with Sonos's decision in regards to stopping support for S1 equipment. It takes years or decades to garner good reputation and I think Sonos should have continued to support all their customers regardless what gear they have.
** Man of Leisure **
Thanks, Sam. So far, I have not received any pushback for supporting my Connect. I submitted a diagnostic report when I received a Sonos dropped connection, and their response was that it revealed some network interference, possibly in my local WiFi. I commented that I had seen Deezer dropped connections while the Connect had a temporary direct Ethernet connection, and my conclusion at the time was that my WiFi was not the root cause. Last night, I re-connected the Ethernet cable and powered the Boost off. After about an hour of listening to a Deezer stream, I had a dropped connection and was able to capture a new diagnostic at the moment the interruption occurred. I am waiting on their analysis of the new diagnostic.
Hi Jerry, that is definitely good progress in terms of attempting to troubleshoot the problem. Hopefully, Sonos will get a deeper insight into the issue which may help them to pinpoint where the problem is.
One of the issues with Sonos devices is that it's own wireless protocol (SonosNet) is still active even after a Sonos device is connected via ethernet (wired). I'm not sure if Sonos rectified this issue with the second generation devices but I presume not because Sonos is primarily designed for wireless operation. Hence, there are ways to switch-off the wireless feature in each device (WiFi and SonosNet) so that they depend solely on the wired infrastructure. This reduces wireless interference.
However, before looking into such stuff, let Sonos tech support give you feedback. Here is an interesting article / explanation:-
Yes, that is an interesting article, thanks for sharing. I suspected SonosNet night still be active, so when I tried the Ethernet connection, I powered of both the Boost and my second Connect in the bedroom, assuming that this would turn off SonosNet.
I have not received any additional comments from Sonos support following the Ethernet connection test, and whether they were still seeing any type of interference. I am about to start an evaluation of Roon, for which I will also be conducting a 30-day trial of Tidal, since Deezer is not supported by Roon. Other than the issues I have been having with Deezer, I have been a happy Sonos user. But the Deezer issues, combined with the relegation of the Connect to S1 status has heightened my interest in alternatives. And Roon users are pretty vocal in their praise of the product.
I had an issue with my NAD BlueOS where if I played something from Spotify and cast it would shut down after about 12 minutes. Once I finally got around to trying to do it via the BlueOS app instead of Spotify it seems to work.
I have no idea how Deezer is set up, but maybe it’s something weird like that. However, Sonos’ integration is miles better. Plus, sounds you haven’t been doing anything different - it just stopped working properly.
Are you using Bluesound? Been trying to establish how a pair of BS Flex 2i sound when paired with the new BS Sub+ compared to a pair of Sonos Play 1s and the Sonos Sub.
It’s built in to my NAD integrated amp with a pair of bookshelves, so I can’t compare to my Play1 or 5s.
Hi Jerry, did you hear back from Sonos?
Hope they work towards resolving the problem.
I know Sonos got a lot of flack - deservedly - for the legacy product and app fragmentation situation, but while reading this article on Google services it reminders me how Sonos has always tried to do right by supporting as many services as possible.
I’m not in a Google media user, but this sounds like a really pain.
Strangely Google music is still working for me. I moved my library over to Youtube music, but unless I pay, it won't stream on Sonos. You'd think that Sonos would be able to do a better job of playing my own music. I used Google for the excellent "I'm feeling lucky mix". With Google, I don't pick a genre or band, it just starts playing.
Update on my Deezer streaming issue: I called Sonos support directly and was connected to a young lady named Nicole, who was very knowledgeable and helpful. She connected to my computer, and we browsed my router settings and a few other things, ran a fresh diagnostic, but we were unable to shed any light on why I am experiencing the lost connections while streaming Deezer. She offered to escalate to Deezer for me, but I recommended that I try a one-month evaluation of Tidal first. Since Tidal is also lossless FLAC, if my own infrastructure is the root cause of the issue, it should manifest itself while streaming Tidal as well. If Tidal works flawlessly, the we can escalate the issue to Deezer and, if that doesn't identify and resolve the issue, I will cancel Deezer and switch to Tidal.
Unfortunately, switching music services introduces a lot of work. All of the saved entries in "My Sonos" refer to Deezer music, so they will be rendered invalid and will have to be re-created. Too bad there isn't a utility program that could scan My Sonos and switch music services references automatically.
Hi Jerry, I'm glad you finally received meaningful help from Sonos.
Thanks, Sam. I have started the Tidal evaluation, and have been listening to the Tidal stream all morning. Through several albums, no signal loss so far. Fingers crossed!
I already posted this in the X900H owners thread but figured I would give a shot here;
Anyone use a Sonos beam with this TV? Just bought the beam and 2 one SLs and wondering how the lipsyncing is. I just returned the TCL Alto 9+ after I had audio delay issues and I would like to know the overall experience of the Beam with a Sony TV.
Well if you had your beam connected directly to your TCL I suspect you will get the same result with the Sony tv connected in the same manner.
The optical and hdmi arc connections on both tv's should work fine.
If you have another device in between them that could be an issue (again, for both TVs).
The TCL was the soundbar that I was having lip syncing issues with via HDMI ARC and that has since been returned. The beam is out for delivery today I’m just hoping I have a better experience with it as I have read that LG / Sony seems to have some issues with Sonos.
So, for anyone using the Sonos Arc, is anyone using it in a large open concept room with tall/vaulted ceilings? I bought the Arc, Sub and two Sonos One's for an HT setup while we build a new house. The new house will have about 10000 cubic feet in the main area that includes open to the kitchen. The guy at Best Buy advised of the ceiling heights and room size as to how it will affect Atmos from the Arc. He also advised that adding a Sonos Amp with speakers as front surrounds would fix that problem. Then recently while I'm back there looking at outdoor speakers, we chat again on the room and Atmos subject. He now says that previous plan won't work, in fact this time he says the Arc will never fill a room that size, saying I should go back to a traditional AV receiver with a sub for that kind of room.
Now I have a setup that I cannot use and wonder if he just doesn't know what he's talking about or if I was led astray in purchasing this. I am already looking at a house full of Triad speakers now if I have to go that route. Has anyone else used the Arc in a room that size?
E
