41 - 60 of 1424 Posts
So I got an X800M2 to play with and I found that too determine if the disc has Dolby Vision encoding you should enable Dolby Vision output on the player, then start the disc.
Once the disc starts you press the "Display" button on the remote and the player will tell you if the disc has Dolby Vision encoding or just HDR, and that the player is outputting Dolby Vision to your TV.
Doing it the other way - leaving Dolby Vision off and pressing the "Display" button will tell you the disc has HDR encoding and that the playing is outputting HDR - it does not tell you if there is the disc is Dolby Vision encoded.
This is what it looks like when play Blade Runner 4K which is only in HDR when the Dolby Vision output is ON. You would want to turn Dolby Vision off so the correct HDR mapping is used.
I'm not an expert on this by any means, but it's my understanding that Dolby Vision is a superset of HDR10, and that in fact any Dolby Vision title has an HDR10 base that is used on a non Dolby Vision display.
So, extrapolating that out, if you use an HDR10 source disk such as Blade Runner, if you select Dolby Vision as the output format, all it'll be doing is outputting the HDR10 metadata even if it says it's DV. So there won't be any modification of the metadata and the display should be identical to if you output it as HDR10. The only variable I can see here is if there is some sort of profile on the display device that modifies display settings if the source says it's DV and not HDR10.
Is there anyone who understands the specs well enough to confirm what actually gets output from the player in this situation (HDR10 source, player set to DV output)?
  • Like
Reactions: DataSquid
I think that's the problem though. On the LG C8, HDR10 picture modes default to OLED Light and Brightness to 100. In Dolby Vision, these are set to 50. OLED Light in Dolby Vision picture modes affect gamma. I think there may be negative effect on the picture if the player sends HDR10 metadata but triggers the TV's Dolby Vision mode.
X800M2 Remote
Anyone else think the remote for this 2019 4K player is a step (or several steps) back? I still have my BDP-S350 player and its remote is much better. I am using my old remote for this X800M2.
Keeping an eye on this player. I have both the original X800 and X1000ES and relegated them to secondary setups due to the too-often freezing/stuttering on new discs that often required unplugging the player (easier to do on the ES unit than the X800 due to the power cord being hardwired in). If they have addressed this on the Mark II player then it's a winner, Dolby Vision toggle annoyance and all.
Currently have an Oppo 205, UB820, and UB900 that I'm happy with but the 900 is a bit outdated at this point.
I finally got my new x800M2 set up. I tried out a few scenes from the 4K blu ray of Ready Player One. I haven't bought many Dolby Vision discs because of the raised black bug. I am happy to report I saw no signs of the problem. I went to scenes that I knew had the issue with the LG player and blacks were nice and deep. No sign of noise in the black bars.
The player itself is an upgrade over the LG UBK90. It has a much better build and much more responsive. I also found the upscaling to be better. the LG player looked good on most 1080p Blu Rays but could look off on others. For example, Pixar movies looked soft to me. I watched a bit of Up tonight and it looked much better. I tried the Auto1 setting and then turned off upscaling altogether to let the C8 handle it. I think I liked those results even more. The fact that I could send a native signal to the TV or to whatever equipment I might have is a welcome addition.
The player came with 2 free movies. Spider-man: Into the Spiderverse and Jumanji: Welcome to the Jungle. I watched all of Spider-man tonight and was very pleased with the performance. That only has HDR10 though. I don't really have a great desire to watch Jumanji again, but I'll pop it in tomorrow and at least watch a bit. It is Dolby Vision and will give me another chance to test whether I get raised blacks or not.
But, so far, so good.
5.1.4 Setup with Dolby Vision capable OLED
Appreciate your thoughts on the new player. Thank you.
Is Anyone with a Lg C8 and UBK90 for sure going to have the Dolby Vision bug? I ask because I am not sure I have it. You mentioned a few known scenes in Ready Player One that show the bug. Would you mind listing those scenes?
The raised blacks bug was supposed to have been fixed, although some people are still claiming to be having problems.
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1544445203
Look at the scene where Perceval and Artemis go see the Curator at the Halladay museum while searching for clues. That whole extended scene has the bug. Blacks will be perfect then the movie cuts to a reverse angle and suddenly there it is. Then there is another edit and everything is fine again. Drives me crazy.
Banned
what is the difference between the 800m2 and the x700? The BB salesman recommended the x700 said there was no difference between the 2.
Netflix, Amazon prime, YouTube are the three apps.
Have you tried Amazon Prime Video on this player? Is it a built-in app that actually works?
X800M2: DVD-Audio, DSEE-HX, rigid chassis/8 lbs.
  • Like
Reactions: Transistorious
A far more premium build. Better audio section when playing hi res audio formats like DVD-A and SACD. It also offers Bluetooth connectivity for connecting wireless headphones. As far as video, I do believe there is no major difference. We assume Sony took the video subsection of the X700 and put it in an X800. This hasn't been totally confirmed though. I think we would need someone to do a comparison between the two players with 4K UHD and in upscaling 1080p Blu Rays before we know for sure.
Banned
I see. So there is really nothing compelling about the x800. Interesting marketing choice for Sony. Must have been to rush to have something to have at the consumer electronics show.. I can see whey the BB salesman recommended the x700.
Thanks for the scene. I will take a look when I have a moment.
After some posts in the Elevated Blacks in DV Thread I made last night and some testing, it's looking more and more likely that at least in my case, I don't seem to have the Dolby Vision bug. I tried content from my Apple TV 4K, UBK90, and x800M2 and the only issue I found across all 3 for Dolby Vision content was that my Brightness should of been set to 49 instead of 50. I can chaulk mine up to just being a variance in my panel vs having some kind of bug.
But back of topic, I am liking the M2 so far, manual DV switching or not. All things being equal, it's clearly better than my UBK90 and at least it is possible they can add auto switching DV with a firmware update. No amount of firmware updates can change the build of the UBK90. :)
But back of topic, I am liking the M2 so far, manual DV switching or not. All things being equal, it's clearly better than my UBK90 and at least it is possible they can add auto switching DV with a firmware update. No amount of firmware updates can change the build of the UBK90. /forum/images/smilies/smile.gif
If you need to set your brightness to 49 to not get the elevated blacks, then you have the bug. Try watching Dolby Vision content from internal apps with your brightness set to 50. If everything stays pure black, then it isn't a panel variance thing.
Anyway, I tried some scenes from Jumanji just now. Everything looks good. Black bars were always black. So far I'm liking this player.
I have a question. There are some picture modes on the player itself one can switch between while watching a movie. It's cute the pop up menu that comes up when you hit the options button. One of them is Direct. Am I right in assuming that this sends the picture to the display without any additional processing?
I am experiencing an issue where I have to physically unplug the M2 unit from its power outlet and plug it back in for it to power on about an hour or so after it has been powered off. I updated to the latest firmware. I just turned off Quick Start and will test if that's causing the issue, because my original X800 had issues with Quick Start turned On (not starting up 100% of the time).
Has anyone experienced this? And is there a way to hard reset the M2 with physical buttons?
Update:
Leaving 'Quick Start' (OFF) seems to have corrected the issue. It powers on even after hours of non-use. It's up to Sony to fix the bug.
I had a problem with the first 4k movie I played, which was ready player one. Movie would freeze at the exact same spot somewhere in chapter 11. Eventually I put in another 4k disc and that played ok. I tried RP1 again and the freezing issue was gone. Is this what you experienced with the x800?
Premium Member
So far two discs in hdr dtsx Jurassic Park, and new 4k hdr dtsx backdraft, one hour of aqua an Dolby vision atmos no issues no freeze ups great pq and audio Had 700 and 1009eS in past freeze ups returned. So far disc playback on this machine is fine if it keeps up its a keeper. A good backup to my Panasonic 820. Despite some operational annoyance both are great disc players.
Just an FYI for owners:
The Sony WSUBPRE1 rack mount kit made for the ES UBP-X1000ES 4K Blu-ray player also fits this player. I have mine rack mounted with my other equipment. Very good quality. You can find them at a pretty good discount.
