Hi. There is a 570 vs 590 comparison here:
From all reports there is a significant difference in HDR of the new models vs the previous generation. That was an HDR comparison!Thats a great add, but can't believe the older models look as presented. The 570 images look washed out as if there is a filter on the lens.
Indeed, there is no baseline frame of reference between the two units.Thats a great add, but can't believe the older models look as presented. The 570 images look washed out as if there is a filter on the lens.
That is the key word. A difference isn't always an improvement.From all reports there is a significant difference in HDR of the new models vs the previous generation. That was an HDR comparison!
Keep in mind that some reviews have suggested that the new models may "overcook" HDR to give even more pop, to match the pop on flat panels!
I am reporting what folks who have actually seen the machines have said. Almost every reviewer who have seen the new machines have said that the HDR image is clearly better than the previous generation. Many have said that the perceived contrast and sharpness is also much improved. Now those are subjective opinions and need to be individually confirmed.That is the key word. A difference isn't always an improvement.
They had to do something to try to demarcate the new ones form the current ones, and if it is an over pop of colours etc in HDR, then it would have the desired effect.
The only thing going for these new machines is they are significantly cheaper.
That is a win, for sure! But, one that wouldn't have happened with truly new hardware.
No, I haven't but I have spoken to some that have and they say there is no real difference.Given that you have not actually seen any of the new models, I am struggling to get your point? You seem angry that Sony has delivered new products? Tech moves on, it does not meen that your projector is not great!
Thanks man! You know it!I have no axe to grind here I would love to see an independent review of both old and new to see just what's different. I am sure there are differences but it will ultimately take someone to do an in depth comparison to see what they are.
P.S. @Archibald1 images are to die for............ REALLY.![]()
Not the only reason I would say, but it is undoubtedly one of them.^The only reason why they might have released now is that everyone has been claiming they are pulling out of the projector business and releasing new models would convince that they aren't.
Maybe but the virtual CEDIA show just happened, so this is the normal time in the projector market to release info about upcoming product line.^The only reason why they might have released now is that everyone has been claiming they are pulling out of the projector business and releasing new models would convince that they aren't.
Sony would do much better here in the US if we had your pricing.You have seen what our US cousins pay for Sony's right? We are the ones sitting pretty there for a change.![]()
You cannot use that video to judge that I am afraid.Difference between the 570 and 590 looks good. Greta to see projectors getting better at HDR.
Recently changed my settings a bit when watching 4k movies using my Panasonic 820 and my Sony 695ES, and the settings really have improved the enjoyment of watching a movie for me, so thought I'd share.Here's the settings I have settled on for now after a recent calibration by Chad B:
Panasonic 820 settings when watching 4k discs:
Optimizer On, Slider at 2 (though this can vary from movie to movie, I generally keep it between 0 and +2 to start with, and go up to +4 if needed, rarely going past +5)
White Gamma: 0
Black Gamma: 0
Edge Correction: 1
Sony 695ES settings when watching 4k movies (the UB820 and Nvidia Shield both use the same Cinema Film 2 preset, but the UB820 is passing SDR 2020 so that it can control tone mapping with optimizer settings above, while the Shield is set to HDR 2020 and the projector handles tone mapping). Also, note that Cinema Film 2 has been calibrated to a 2.4 gamma, which is needed for proper tone mapping since the Panasonic expects a 2.4 gamma.
Calib. Preset: Cinema Film 2
Contrast: Max
Brightness: 50
Color Temp: D65*
Reality Creation: On, Resolution 45, Noise Filter 0
Contrast Enhancer: Off (or Low)
Lamp Control: High
Gamma Correction: 2.4
Smooth Gradation: Low
Color: 55
Sharpness: 50
Hue: 49
NR: Off
Motion Flow: True Cinema
Input Lag Reduction: Off
Advanced Iris: Dynamic Control: Full, Brightness 91
Clear White: Off
x.v. color: Off
Color Correction: Off
HDR: Auto
Color Space: BT2020
*If D65 is not bright enough, I have also setup a Custom3 setting, which is basically D65 with the RGB Gain turned up from 128 to 152. May or may not need this in your setup to get decent HDR effects. Instructions at bottom if you need them.
Here's the settings I use for 1080P movies (both for the UB820 and the Nvidia Shield):
Calib. Preset: Cinema Film 1
Contrast: 99
Brightness: 50
Color Temp: D75
Color: 50
Reality Creation: On, Resolution: 30, Noise Filtering: 0
Lamp Control: Low
Gamma Correction: 2.2
Sharpness: 50
Advanced Iris: Dynamic Control: Full, Brightness 96
NR: Off
Color Space: BT.709
Clear White: Off
x.v. color: Off
HDR: Auto
Here's my 3D settings:
Panasonic 820 settings when watching 3D movies:
Display: Projector
Picture Type: Normal
Tone Curve (White): 0
Tone Curve (Black) 0
Edge Correction: 1
3D signal format: Normal
3D popout level: 0
Sony 695ES settings when watching 3D Movies:
Calib. Preset(3D): Cinema Film 1
Contrast: 99
Brightness: 40
Color Temp: D93
Reality Creation: On, Resolution 25, Noise Filter 0
Contrast Enhancer: Low
Lamp Control: High
Gamma Correction: Off
Color: 51
Sharpness: 50
Hue: 50
NR: Off
Motion Flow: Smooth High
Clear White: Off
x.v. color: Off
HDR: Auto
Color Space: BT.709
Here's how to turn up RGB Gain to get a bit more brightness when watching HDR content:
Enter into Service Menu by pressing "Enter, Enter, Left, Enter" on the remote control
On the left hand side of the menu, where the icons are, go all the way to the bottom and select "Device"
Under "W/B", select Custom3 (which is based off of D65)
Adjust R, G and B values up from 128 to 152 for each and click Enter until you go back to the main area, then save changes
Now you can select Custom3 and you will have more brightness/pop when watching HDR content (in addition to setting lamp mode to High)
Edit: I have tried the dynamic iris at 75, 96 and 91, and settled on 91 for now. Keeping the dynamic slider low (between 0 and 2) is the only thing that really keeps the contrast set properly for me, and setting the iris to 91 seems to be the best blend in terms of keeping black levels good while also providing a bit of brightness in darker scenes. This was the best combination I could find after testing several more HDR movies.
Edit: Finally got around to testing out some 3D movies, so added those settings as well.
