41 - 60 of 4934 Posts
I just watched Transformers on my new 52inch XBR, PQ is unbelievable. Sharp as a nail. I was really blown away by the experience. This was the best experience I've ever had on high def disc, no kidding. Too bad the movie wasn't that great. The HD-A35 delivered, yet again.
ordered my A-35 from the states yesterday. we havnt got this model here in australia yet so im looking foward to receiving it soon. its good to get all this good info from you guys here.
also can anyone recommend wheres a good place to buy hd-dvds from? over here in australia blue-ray seems the go but im going down the hd-dvd track
I have a question:
After a power failure or firmware update, the unit asks me to set the time. After doing so, it just says "WELCOME" on the unit's LCD and the screen remains black until I hit a button to open the tray or whatnot - it then works normally. Everyone's unit like this? Trying to see if this is related to the problem below or if this is a normal player response.
Originally Posted by SPLawren /forum/post/11964142
Done and done.
Unfortunately, I seem to have two persistent problems even after the firmware update.
1) the player doesn't start up the first time I push the power button. it hangs with the "welcome" on the front panel and does nothing - no HDDVD light illumination, no response to button pushes, etc.. I have to then force it to power off by holding down the power button for 12 secs and then immediately push it on again, and then the player will startup. Anyone else with this problem? Thoughts?
UPDATE: Called Toshiba tech support - they said this was a hardware problem and to send it back for repairs. GRRRRR. Calling VE for a replacement. . . AND replacement on the way . . .
Before you send it away, try this as I had the same problem:
Go to the place where you did the firmware update and hit "Initialize". That seemed to fix the problem #1 you listed for me I had a while ago.
Originally Posted by Ruined /forum/post/11965473
I have a question:
See my reply in the other thread you posted to.
Immaculate Grand Phoobah
Originally Posted by joerod /forum/post/11964121
Watching Transformers lastnite with that great D.D.+ soundtrack was awesome!
I watched it yesterday morning and agree with you completely!!! WOW!
whoohoo! I had an A30 and a copy of Miami Vice (I think some of you already know this story) which kept hanging up at a certain spot in the beginning of the movie. I exchanged the A30 for an A35 and another copy of MV, still hung up in the same spot. I just updated the firmware and decided to try the movie again...it works! Played right past the problem spot with no stutters or anything. I am one happy camper right now!
After the credits started after Transformers, I turned to my wife and said "This is what HD DVD was invented for". We were in awe of the PQ and AQ. I still cannot believe it is a DD+ track. I cannot imagine how good a TrueHD audio track would sound like. I can't get enough of the movie. Neither can my 4 year old son.
I wish I would have kept my A2 to compare it to the 35. I still kind of dream about the XA2. I'll get over it. This is an awesome device. Also, I cannot stress enough how cool it is to have a wife that supports, enjoys and even understands HDM and the improvement in AQ and PQ compared to SD.
Regards...Will
Banned
Do the in player settings in the A35 affect the HDMI audio similar to the XA2? With the XA2 you need to set all speakers to large, SPDIF to bitstream, all settings at 0 to get the most out of the HDMI audio output....Is the A35 the same way and if so what EXACT settings should be used to max the HDMI audio output? I have an Onkyo 885 so I will be using bitstream for the advanced audio codecs since this pre/pro can decode them. Any settings I need to know about?
Originally Posted by Will Munshower /forum/post/11962296
Is it just me or does it seem like a vast majority of members who bought an A-35 also own an HDMI 1.3a capable receiver?
I wonder why that is?
Hi Will,
First of all, thanks for the info on imports and A35 bitstream DTS MA capability. Not only will I go to the bath room, I will cut up all my credit cards too otherwise I will buy everthing
As for your observation, why did you ask that? I think ppl who wants A35 knows what it can do and they want the A35 to do it, namely, bitstream lossless audio. Which means you will need a mid to high end receiver that is capable. Are you saying ppl should just buy the cheaper non hdmi ones and just let the A35 LPCM? Well, if ppl don't mind LPCM or don't know about it, they probably want to spend less than 499 or 599 (I forgot...damn, I should look at prices before buying stuff more often to avoid bankruptcy). I mean you can get HD DVD for xbox for 170...
To be honest, when I first got into blu ray and HD DVD, I did it for the picture quality, not audio. That's why I bought a 60 inch 1080p plasma. Crap, I was even just using the tv's speakers for sound and worse, I use those IR wireless headphones when my wife is sleeping. Then I discovered a/v receivers and surround sounds and DTS MA and DTHD and all this gimmicks, then I started upgrading. Stopped using PS 3 as my blu ray and gave my HD DVD xbox player to my friend. I first got a sony 3300 ES and then a denon 3808, realized 3 HDMI in are just not going to cut it and so I upgraded to 4308ci denon with 4 hdmi input and 2 output and its still not enough (I think denon makes one that has like 30 hdmi input but it costs like 7500...I think I will just buy a hdmi selector or buy another 4308
) Now my wife and I don't even go out to watch movies unless it is a chick flick and I will go to the theatre to sleep...
Is this what you meant in your questioning?
BTW, anyone has any exp with those psyclone hdmi selector? Are they 1.3a compliant? Well, I was just gonna hook up my PS 3 and xbox and Directv Tivo...so doesn't matter, they are all DD for games anyway).
Well, it's kind of a public thing that those of us who like the AQ of the receiver doing the processing catch a lot of flack. To me, LPCM was great. In my opinion, and from my experience as a musician, I like the AQ more with the receiver doing the heavy lifting. It's not a level issue (I checked all my speaker levels with an SPL meter). I, and more than a few others find it more appealing. Since I am not an acoustics engineer, I cannot explain why it sounds better to me.
I am in no way saying everyone with HBR capabilities should run out and buy an HDMI 1.3a receiver. I was just cracking a joke about the appearance that a majority of us who do own one, went for the A-35.
There's really no way to go wrong with the 35. If you have HDMI that has LPCM capability, great! Just go LPCM. If you don't have HDMI, that's cool too. Use the 6 analog RCA jacks and connect them to your receiver.
Additionally, I like the PQ capabilities of the 35 as well. Like I said, you really can't go wrong with this puppy!
Regards...Will
Regards...Will
Maybe your 4yr old and my 7yr old can watch it together as I have watched it with him 6 times and he is telling all of his little school mates to come to his house and watch it in his Home Theater.
My A35 with my Samsung SP-H710AE is stunning.
Discussion Starter #54
Yeah, tried that twice - no dice. Did you also have trouble navigating SDDVD menus, like me?
Great idea!
I'm tired of reading 'should I get the A3 or A1' posts in the A3/A30/A35 thread.
Could you add to the OP, what the 1.1 filmware upgrade fixes?
THX!
Has anyone else had the issue, when you updated to 1.1, the PiP, IME, etc. has no sound?
I popped in several different movies with some kind of picture in picture feature, whether it is U-Control, IME, etc. when the PiP shows up, there's no sound accompanied. The normal movie soundtrack continues.
I should also mention, I am using this unit with a Denon 4308CI and I have it set to pass the bitstream, if that makes a difference.
Originally Posted by Will Munshower /forum/post/11962278
Yes, set the optical setting on your 35 to bitstream. You will then have access to 1.5 mbps DTS. It's not DD+ or TrueHD but it's no slouch, either.
To check your firmware revision, go to setup and then the 'general' tab. Then go to 'maintenance'. Under maintenance, there is another button...Update. Push update and a box will pop up. The current format is:
xx/yy where yy is your version number. Most, if not all out of the box 35's will have 1.1/1.0. You will need to update to 1.1. When the update is completed, when you check again, it should read 1.1/1.1.
I hope this helps...Will
This did help. Thanks Will.
This is the problem with using a bitstream output. Dolby has written about this at length on their website in their DD+ and TrueHD for receivers articles.
With all previous players (HD-A1 through HD-A30), there was no option to output the audio in bitstream form. The DD+ or TrueHD audio for the movie was being decoded into 5.1 channel PCM inside the player.
HD-DVD players also have a second audio decoder. This second decoder is for the things you mention, like PIP commentaries, U-Control, IME, etc. Any sound that is not the movie's own soundtrack is being handled by the second audio decoder. All those secondary audio sounds are also decoded into PCM inside the player.
Then, the two PCM soundtracks from the two seperate decoders are mixed together into a single PCM signal that is sent out via HDMI to your receiver. With the HD-A1, HD-XA1 and HD-XA2 (and the HD-A35 if you are NOT using the bitstream output), that mixed PCM can also be processed through an internal DAC and be output as an analogue signal using the 5.1 analogue connection. And in all players, that single, mixed PCM signal can be sent through a DTS encoder and output via optical or coax S/PDIF so that any receiver that has a DTS decoder can play back the audio.
But when you set the HD-A35 to output the DD+, TrueHD or DTS-HD:HR/MA signal in bitstream format, there is no way to mix the audio from the second audio decoder inside the player. I'm am not completely sure what the HD-A35 is technically doing. My guess is that the only audio that is being output is the DD+, TrueHD or DTS-HD:HR/MA bitstream and that the secondary audio is simply not sent at all.
But even if the secondary audio IS being sent, there are no receivers available that can mix two audio sources at once. Again, my guess is that the HD-A35 is only sending the one bitstream because I'm sure sending two seperate audio signals to any receiver would muck things up in a major way!
So this is why bitstream output isn't necessarily such a great thing. At the moment, you really only NEED bitstream output for DTS-HD:HR/MA and that is because the HD-A35 cannot decode those formats internally. It can decode the 5.1 DTS "core" that is embedded, but you lose the extra extensions that give you the "high resolution" or lossless "master audio". So having the option of bitstream output is great if you import and you have HD-DVD discs that actually HAVE DTS-HD:HR/MA audio tracks on them. For virtually all North American HD-DVD releases, the player can internally decode the 5.1 DD+ or TrueHD audio, in which case it can be mixed inside the player as described above.
The other situation in which the bitstream output will be needed is if we start to get 6.1 or 7.1 channels. Right now, all the HD-DVD players out there only decode 5.1 channels of DD+ and TrueHD internally. A firmware update might be able to expand the internal decoding to 7.1, but I'm not at all sure. Toshiba makes specific mention of being able to output 7.1 channels using the bitstream output though when they describe the HD-A35 on their website.
So, in closing, if you want to hear the secondary sounds from PIP, U-Control, IME, etc., you will have to let the HD-A35 decode the DD+ or TrueHD movie soundtrack internally so that it can be mixed and output as a 5.1 PCM signal. If you are listening to a DTS-HD:HR/MA soundtrack, you will have to use the bitstream output and thus, you won't be able to hear the secondary sounds. And that will also apply if we ever start to see 6.1 or 7.1 channel releases on HD-DVD.
And just for the record, all of this will also be true of Blu-ray profile 1.1 and 2.0 players. They handle audio is exactly the same way, with two audio decoders delivering two PCM tracks that are mixed together and output as one multi-channel PCM stream to your receiver. The new Sony S500 and S2000ES can internally decode DTS-HD:HR, but they cannot decode DTS-HD:MA and as a real kick in the pants, they can't even output DTS-HD:MA in bitstream form, so all those Fox titles cannot be heard in their full glory! The Samsung P1400 can output DTS-HD:HR/MA bitstream, but cannot internally decode them. Although it doesn't really matter since it's a profile 1.0 player and has no second audio decoder anyway!
It appears that the dual format LG BH200 will be one of the first profile 1.1 Blu-ray players (it may even be profile 2.0 aka BD-Live - BD-Live is actually mentioned by name in LG's own press release from Sept.5), but all the info points to it being able to output DTS-HD:HR/MA as a bitstream, but no internal decoding. The PS3 may actually be the first player to get internal DTS-HD:MA decoding and the Samsung dual format UP5000 may also have internal decoding - bitstream output seems to be a lock for that unit.
Jon
Originally Posted by mosman22 /forum/post/11964578
I posted this in the other all inculsive 3rd gen thread. Since i had alot of problems getting 1.1 on my player i figured i would post this here too.
This is a link to the program i used to burn the the firmware 1.1 iso to cd, http://www.ntfs.com/iso-burning.htm , thanks IBL8. I couldn't update my through the ethernet port, and when i tried using my regular burning software my a 35 wouldn't reconize the disc. It wasn't until i used the iso burner in the link at 2x speed that i finally got my player to reconize the cd and in about fifteen minutes my firmware was updated. Since doing this i have gotten no error messages or audio dropouts.
I too was having problems burning an ISO CD. This download worked perfectly. Just updated to 1.1. Thanks for the great info!
