"Image Offset" is a constant per centage of image height. It is not a constant distance!
A 92" screen has a height of 45". If the offset distance on your 92" screen is 16.2", then your "Image Offset" is (16.2/45=) 36%
If you increase/decrease the size of your image by zoom or projection distance, the "Image Offset" distance will also change but will always be 36% of the resulting image height.
If you move your projector and adjust the zoom to remain at a 92" image, the offset will remain the same.
