Status
Not open for further replies.
1 - 10 of 10 Posts
I need some help....i have a 32inch sony vega HDTV and i am getting an XBOX. now, when i connect it with component video cables....what will the aspect ratio be. It says i can choose bwtween letterbox, widescreen or standard.
When i view some dvd's...they are very skinny ( the picture ).
When i view HBO-HDTV....its perfect!! larger screen but still has block bars but i want it o look like the HBo-hdtv aspect ratio?
can i do this?
If anamorphic DVDs look "skinny" on your set, but HBO-HD looks fine, you need to go into your DVD player's menu and select "16:9 Widescreen" (or some such) instead of "4:3" for display, so that the player will output a widescreen signal from anamorphic discs.
1 - 10 of 10 Posts
Status
