Status
Not open for further replies.
1 - 2 of 2 Posts
I'm having a problem with random reboots whenever the onboard sound is used, and since I am po'r now, I'm using the onboard cmedia 9738 which is astoundingly bad anyways (I can easily tell from the previously satisfactory 8738 I used on the soyo board). This rebooting problem does not seem to be related to RAM or ps unit since crashes only happens when sound is being passed through the sound. I definitly do have an IRQ problem, but I am hesitant to switch around cards because I am using most slots and don't have give space.
here are my specs
2400+
K7s5a pro
256 ddr 2100
ata card
hipix
fusion
430 true power
w2k
Thanks for any help in advance...this seems to be a wierd problem and I cannot find others who've had this problem using google...
Darius
On-board sound chips use the CPU for processing, increasing the CPU load and its power demands.
One of the downsides of a Truepower-type design is the loss of power trade-off capability between the +3.3 and +5.0 rails.
Your board uses the +5.0 rail to power the CPU as well as all those cards.
If the reboots are sudden (ie no BSOD nor error message, just starts to POST), it indicates that the POWER-GOOD line from the PSU has dropped below threshold and the mobo reset the CPU.
Try running at 100/100 (to lower the CPU power load) and/or removing one of the HDTV cards to test the idea.
1 - 2 of 2 Posts
Status
