Well from what I could see in the photo, the cable might have to be changed. Unless you know it is a 75ohm cable. But I may be wrong. The antenna itself seems to be in tacted. All the elements are still attached. Also, where are you from? It all depends how far you are from your local stations' towers. Judging from the smaller size of the antenna the pervious owner may have found it be good enough to pick up locals in your area.
The rotor is old and depending on where you live (cold climate) it may have ceased in its present position. You say you don't have a control unit for it but I see 2 cables coming down. The second one should be for the rotor. You need to find where this cable terminates and connect a turning unit to it. I found that there are a few units on e-bay. A used one will do, especially if the rotor doesn't respond.
