Hello. I've recently acquired a brand new Sega Saturn (standard black North American model) and would like to know what the highest quality cable I can use to output with, without having to physical modify the console. I currently own both a Sony KD-34XBR960 HDTV and Sony GDM-FW900 PC monitor.
Now I know RGB SCART is superior to S-video so I'm assuming RGB SCART is the highest quality cable to output with in this case (since you can only buy an RF, composite, S-video and RGB SCART cable for the Saturn). The thing is, RGB SCART is not a cable my American monitors can use obviously. So I was thinking of buying the Sega Saturn RGB SCART cable and converting the signal to component video with this adapter: http://www.converters.tv/products/co...oducts/46.html . The only thing that I think is wrong with this configuration is with audio. Doesn't the Sega Saturn RGB SCART cable output video AND audio through the SCART cable itself (Here's a LINK to a picture of the cable) In that case I don't think the converter would work because I would get no audio through the component end (since component cables only handle video). So really that brings me to square one. Am I stuck with S-video in this case or is there another way for me to use the RGB SCART cable and have audio? Is there an adapter/converter that takes an a/v RGB SCART cable and convert it to component with RCA audio output for example?
If anybody could help me that would be would be forever grateful.
