mmdd said:
You also need to calibrate the white balance in the service menu(At least in the mico 40)
Does this involve anything other than changing the values in the white balance field of the service menu?
No, just the white balance gains.
But keep in mind that only the preset you have selected in the normal menu is modified.
If you want D65, select this in the menu and then go to the service menu.
It is not possible to change all the remaining settings in the normal menu, only the one you choose.
As for the color calibration, maybe I will. The color values deviate quite a bit but the luminance value is perfect. I don't think it's necessary, but I'll do it to experiment.
