I apologize if my older DLP is not high end and doesn't fit this thread, so mods please delete the comment if that's the case, I only noticed it has the same chip as the original post mentions, and I wanted to ask about it.
It's the Infocus IN83. I really liked it back when 1080p content was the highest available, everything except black level, but I may never have calibrated it. (I am definitely not in the right thread, eh? Lol). It was used and I dont remember if the previous owner calibrated or not. I think not. I had to take it down years ago, but have the option to put it back up now, it would just be a lot less convenient than going to an OLED, which is probably what Im going to do.
How do you judge the difference between 4K OLEDs with HDR, and 1080p DLPS like the IN83 with no HDR? Specifically the Sony A8H, 65 inch. Its smaller than a 100-110 inch projector screen I could set up, but I could sit closer, and get 4K, HDR, and true black. But I am worried about the motion, I am sensitive to motion and generally dont like sample and hold TVs. But one Sony LCD from one year looked good to me, although only 35 inch or so, and Ive had that for years and been happy with it. So my hope is the fact the 65 inch OLED is 10-15 years newer, and OLED, with top end chip, will compensate for the bigger screen and the motion wont bother me.
Assuming the motion checks out, and putting size aside, am I going to get a better picture on the A8H than the IN83? How do 1080p DLPs of this quality fare in general compared to modern $2000 OLEDs? And is the IN83 considered a good 1080p projector despite its lower or mid tier price compared to some in this thread, or is it only good compared to entry level, but has a lot of problems or downsides compared to 3chip DLPS and ones ten times more expensive in this thread that I didnt notice? Because I definitely noticed weaknesses in terms of black level, and on the raw horse power and feature side of things (contrast, 120hz, etc, noise reduction didn't take away tons of noise), but for everything else, color accuracy, sharpness, detail, shadow detail, motion at 60hz and below, it seemed like swinging well above its weight.
And how do PQ especially motion with modern $2000-$3000 4K HDR DLP projectors, new or used, compare with the IN83 1080p non-HDR, and how do they compare to the top of line 1080p DLP ones talked about in this thread? And throwing the NX5 or NX7, or the comparable Sony laser 4K HDR models, into the comparison for good measure would help me get a fuller understanding where I stand and what my options are.
