1 - 3 of 3 Posts
not sure if i have this in the right thread...if not, i apologize.
I just purchased a Olevia 32" HDTV this evening and i am having problems getting ota channels to come up. I only have the standard cable channels (no digital box) with comcast cable. I hooked the tv up and did the auto scan. It found 78 analog channels and found several digital channels. I could only get 2 hd digital channels to come up. So I went out and bought a indoor HD antenna and a gold coax combiner which is suppose to allow a uhf and vhf connection to one tv set. When i hook it all up together, i get nothing (no analog and no digital). If I hook up the OTA HD antenna, I get several HD channels but no analog. Problem is I can't get it all to work together, only seperately. Any suggestions??
try here
Banned
It would seem to me you need an A,B switcher like what Radio Shack sells. You would hook your cable and HD antenna into it with 1 cable going to the RF port on the TV then when you want cable or OTA you would just select either A or B
1 - 3 of 3 Posts
