Status
Not open for further replies.
1 - 2 of 2 Posts
Hi guys. Which is the best way to hookup a DVD player to a Barco Data 800? S video, or is there some way to run the composite out from the DVD to the Barco?
Thanks a lot, I'm a nub (new untrained body)!
Eric
You'll want to line double or triple the signal out of the DVD player for best image quality.
The IScan line doubler is a good (inexpensive) place to start... though your projector will look even better with a tripler.
Check out the video processor forum and start reading!
Use the S-Video input for the time being, but remember that you're not seeing anywhere near the max capability that your projector is able to achieve.
Kal
1 - 2 of 2 Posts
Status
