I have 2 Yamaha YST-SW315 subwoofers. I was using just one and it worked fine so I figured if one it good 2 is better. When I was just running 1 woofer I had a sub cable going from the receiver to a Y adapter which hooked to the subwoofer. It worked great. So now the proble with me trying to run 2 subs.
So now in order to accomodate both woofers. I have a Y adapter coming out of the receiver with a cable attached to each female end. Then I have another Y adapter that hooks into each subwoofer so as that both (L) and (R) are being used on both subs. I don't get any sound from either of them. I was told it is because the Ohms are dropped too low and my receiver now isn't able to transmit the signal. Is this true. Do I need to buy some kind of convertor box to accomodate this kind of setup? What is going on? I didn't know this would cause a problem, I thought all you were doing was splitting a signal.
OH yeah I have a VSX-81TXV Pioneer elite receiver. PLEASE HELP ME!
